JDM ITR hub bearings. same diameter as USDM?
Mr. Badwrench
i have just gotten my JDM ITR 5 lug. i know the differneces between the spline diameter. my question is, can i get a usdm hub to fit the jdm bearing? if not will a usdm bearing fit the spindle? i know this is a pain in the *** but i have D.S.S. stage 2 axles already, and dont want to buy another set. thanks in advance.
Re: JDM ITR hub bearings. same diameter as USDM? (boostedcivicsir)
JDM hub is 36mm just like the prelude. Just swap the hubs on the axles to the larger size. Its really easy to do and shouldn't cost much money at all.
Mr. Badwrench
Re: JDM ITR hub bearings. same diameter as USDM? (GZR4DR)
what i am getting at, is i have DSS stage 2 axles for a USDM type r. if i put usdm hubs, on the JDM bearings, will this work? sorry if i was a little too vague.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">i have just gotten my JDM ITR 5 lug. i know the differneces between the spline diameter. my question is, can i get a usdm hub to fit the jdm bearing? if not will a usdm bearing fit the spindle? i know this is a pain in the *** but i have D.S.S. stage 2 axles already, and dont want to buy another set. thanks in advance.</TD></TR></TABLE>
95.5-97 JDM ITR 5 lug hub = 32mm size
98-00 JDM ITR 5 lug hub = 36mm size
so if you have the 32mm size you can use civic axles in the ITR hub.
FRKWOO
01-15-2011 06:47 PM
NsX_CrX
06-14-2006 09:16 PM
