b16 head question
how dependible is the stock valve train on a b16 head with a gsr block n p73 pistons with a redline of 8200 8500 ....whats da probability a valve falling
great just don't use big aftermarket cams on stock valve train and 8200 sounds good it all depends on when you stop making power some guys run like 9000 RPM but they don't make anymore power they make less and wears on your motor alot quicker
you upgrade valvetrain according to the cams you're running, not what motor you bolted that head on. If your valvetrain is old and high mileage, it won't matter what cams or motor it's bolted to, it can still drop a valve.
iight thanx das only thing i dnt got money for right now i got the whole bottom end done complete with eagle rods arp rod bolts arp mains acl bearings new oil pump n screen n got the block decked n put goldeneagle head studs but i dnt got money to put on da head right now so ill just rap up da block till i can get some seals ,spring and retainers
Scubster
12
Oct 21, 2005 11:12 PM
better da be safe than sorry
