need help with the right turbo for my new setup
Old Apr 12, 2009 | 11:22 PM
NLR808's Avatar
Icon2 need help with the right turbo for my new setup
so i had a stock b16 running a full race turbo kit with a super 60. Ended up sending the block to the grave yard.
so my new setup which i am in the process of breaking in
gsr block
81mm 9 0 1 cp pistons
eagle rods
acl race bearing (if that matters )
b16 head
full port and polish
oversized valves
welded chambers
pritty much everything dave at dh-racing.com could do
blox type-b cams
70mm dh throttle body
ported b16 intake manifold also by dh
so for my turbo setup as of right now
full race manifold
super 60
3in down pipe
tial waste gate and blow off valve (been so long i dont remember the sizes)
750rc injectors (also a fuel pump that i cant remember)
so after all that being said i would like to make + or - 400 hp
not a dd like to romp on it 2-3 days a week take it to the track when i get a chance
i have way to many choices going around in my head any input would be awesome
thanks
Old Apr 13, 2009 | 12:03 AM
project dc2's Avatar
Default Re: need help with the right turbo for my new setup
garrett t3t4 50 trim stage III turbine, pump gas good for 400 Wheel with a great powerband. PM me for some pricing
Old Apr 13, 2009 | 10:43 AM
NLR808's Avatar
ttt more input before i make my decision :D
Old Apr 13, 2009 | 11:11 AM
TheShodan's Avatar
Moderator
A 50 trim, COULD do it, but it'll take over 20 psi...Not knocking it, but just an FYI.
You'll need to be more specific about what you're looking for.
-Budget
-Journal or Ball-bearing cartridge / ability to use or not use water lines, fittings, different flanges, etc
-What exhaust manifold? Do you want B, E, or S, cover? What chassis is this going in?
-There are lots of choices. this is 400 on 93 octane gas, correct?
Old Apr 13, 2009 | 01:45 PM
NLR808's Avatar
-Budget
will go over 1g if i have to
was planning on going journal bearing unless convinced other
going into a eg
92 octane
CRXherbie91
Dec 8, 2012 01:10 PM
megatoninduk
Sep 27, 2010 06:44 PM
2.0 and up
Sep 20, 2008 10:43 PM
civicgeek133
Dec 4, 2006 02:29 PM
Boostage
Dec 16, 2003 02:03 PM
