ok to run turbo tuned/chipped ecu on stock motor?
Old Apr 12, 2009 | 11:07 AM
so simple's Avatar
Default ok to run turbo tuned/chipped ecu on stock motor?
i have a gsr motor that was turbo and tuned on crome with 450cc injectors, friend is finishing up putting car back to stock today with a different block, new piston rings/headgasket/seals etc.
is it ok to run the motor temporarily with the chipped ecu til i can get a stock one? or can i revert the ecu back to stock specs?
its an obd1 gsr p72 ecu chipped with crome.
sorry if stupid question.
Old Apr 12, 2009 | 11:25 AM
FastEg6's Avatar
Default Re: ok to run turbo tuned/chipped ecu on stock motor?
Take the chip out and disconnect the J1 on the ECU. If IIRC, It should convert the ecu back to stock. If the Ecu is Jumped at J1 it'll read what the ecu is chipped as, if it's cut it'll read as a stock ecu.
Here is a link, hopefully it'll clear it up a little more.
https://honda-tech.com/forums/engine-management-tuning-124/activating-chip-chipped-ecu-how-2538146/
Old Apr 12, 2009 | 11:26 AM
jdm inc's Avatar
you can prob revert the ecu bak to stock take the chip out and cut j1 and it should send the ecu back to stock but i wouldnt put that ecu on the stock motor cause it will prob make it run wayy too rich and foul out your plugs.
Old Apr 12, 2009 | 11:58 AM
so simple's Avatar
thanks for the replies guys, the process sounds simple enough. sorry but what does IIRC mean?
Old Apr 12, 2009 | 12:24 PM
Crx Jimmy's Avatar
if you still have the 450 injectors on there I would use the turbo tune. The vacuum portion of the map should be fine and work with the 450s better than the stock map.
Old Apr 12, 2009 | 08:31 PM
FastEg6's Avatar
IIRC is a short term of If I recall, and yes if you can get a hold of some stock injectors and run the stock p72 map.
cghorr01
Engine Management and Tuning
Feb 2, 2010 08:32 AM
gsrjdm00
Dec 30, 2008 11:32 AM
OMG B16
Aug 23, 2005 11:02 PM
95excoupe
Feb 25, 2005 05:25 PM
bearboy80
20
Sep 17, 2003 02:20 PM
