1.25* retard/lb boost b16a
Old Apr 11, 2009 | 02:53 PM
sleepercivic88's Avatar
Default 1.25* retard/lb boost b16a
I just made a base map and street tuned it. Im running 1.25* linear retard per pound boost. I want conservative timing and my question is is this considered conservative on a stock b16a with 10.2 comp ratio. I plan on getting some dyno time within the next month or so.
Old Apr 12, 2009 | 09:20 AM
mtber's Avatar
Default Re: 1.25* retard/lb boost b16a
What engine management are you using ?
Make sure your distributor is synced to your engine management or your timing values will be useless.
Old Apr 12, 2009 | 10:40 AM
The distibuter is synced and im running bre.
Old Apr 12, 2009 | 12:07 PM
mtber's Avatar
You should be fine until you throw the car on the dyno.
Old Apr 15, 2009 | 04:04 PM
Tomdata's Avatar
Something to keep in mind is that the boost retard is based upon the timing values in the last "nonboost" column. so if you have an all motor tune with lots of timing and you just add boost tools and use the retard feature you may still be running too much timing because the calculations started from a very advanced point. Make sense??
ghost14
Engine Management and Tuning
Sep 18, 2012 11:30 AM
93civciv
Dec 4, 2007 05:23 PM
turbo boost
Oct 19, 2007 01:57 PM
CRXLST
Oct 27, 2004 09:45 PM
VspecSiR
Apr 30, 2004 10:47 PM
