Need some info on cam changing.
Old Apr 10, 2009 | 11:26 PM
OoThomioO's Avatar
Default Need some info on cam changing.
Swapping my ls/vtec (b18a bot.,b16a1 head) into my other crx and I decided to re-do some gaskets and swap my b16 stock cams for some gsr cams. I need to be pointed in a directed for the torque of cam bolts. Also need to know what I should use to clean the cams and to wipe them with. I definately wanna do this the right way, so looking to get whatever info you guys willing to give.
Thanks
Old Apr 11, 2009 | 05:30 AM
JavierOfReno's Avatar
Default Re: Need some info on cam changing.
clean the cam with brake cleaner and wipe with a clean rag. be sure to use lube the cam before you install it. what do you mean you need to know the cam bolt spec? the caps or the cam gear bolt? do a search for the specs they are on here
250r king
Mar 13, 2010 10:32 AM
1BADEGDC2
Jul 9, 2008 06:45 PM
erikiksaz1
Feb 26, 2007 04:16 PM
NoDestinationSi
Feb 19, 2005 10:00 AM
acatak
Jan 23, 2003 02:15 PM
