No Voltage To the ICM
Old Apr 10, 2009 | 11:25 AM
rdssk8rcs1's Avatar
Default No Voltage To the ICM
What inputs is the computer looking to see to allow voltage to go to the ICM? I check for voltage at the ECU and there is nothing.
Any input and ideas are appreciatted. Thank you in advance.
Old Apr 10, 2009 | 12:19 PM
srmofo's Avatar
Default Re: No Voltage To the ICM
does the ecu have good grounds, there are several, make sure all of them are good. Is it getting power? If the above 2 are good then I might throw another ecu at it and see if I get power going to the ignitor
Old Apr 11, 2009 | 07:48 AM
fcm's Avatar
fcm
Old Fart
Do you have power on the black/yellow going to the distributor assembly, [when ign. switch is in run and start]?
What is the MM&Y of the car? 94
civicmulisha
10
Dec 26, 2009 10:56 AM
KraziCivicSi
Dec 22, 2007 10:07 PM
MrMayhem
Nov 22, 2005 07:54 PM
mockujin
Nov 14, 2002 07:43 PM
