Car Not Starting. HELP ASAP!!
ok heres the deal. i left my lights on last night. went to start it up battery was dead. i was even getting a turn over it was so dead. it was a 2 year old battery. i tried jumping it off, it stayed the same no turn over what so ever, headlights wouldnt even turn on. so i decided just to get a new one. i got a new battery and its pretty much doing the same thing like the old one. what could be the issue!! help me asap!!
So to clarify: no lights at all are working? everything is completely dead? brand new battery never been used? everything was working properly before leaving the lights on?
Check to make sure the ground wire is bolted to the shock tower properly. Check to make sure the connections at the battery are clean and tight. Open the underhood fuse box to make sure the little screw bolts are holding down the wires in the right place so power can get to all of the fuses.
everyone here so far as iv seen treated me with respect, (davefromPA has help me out ALOT!!) and im greatful for it. i hope i dont see any crap talk :D. im so glad i got this fix for only 4$ i almost went and got a new starter!! im not really smart with motors and this place helps me learn sooo much. thanks guys
yeah ive learned alot on this site but then u get those D bags who think they know everything and flame people and just take a thread that can be informative and make it a shat talking match
1993 Honda Civic DX 5spd
Similar problem. Car electronics work, put the key in the ignition, Clutch in (ALL THE WAY), turn they ignition key - Doesnt turn over ( Just clicks, Will make video if my roommate lets me use his camera )
try a few more times, nothing...
Then pull out the key, put it back in, try again, nothing.
Then pull it out, put it in, push clutch, turn key, fires up, no other problems...
The key is not the original.
(will make a thread as soon as i get pictures of the car, pretty clean for what it is???)
i have a similar problem with my Honda Civic EX Year 97.
battery i fully charged, has gas, oil is good.
was running fine, but was parked for about a month without turning it on every once in awhile and now wont start. The spark plugs should be in good condition, they were replaced last year.
what can it be?
what can it be?
if it was sitting for a month then the gas could be bad, especially if its been done more than once without the gas being changed.
it does at least turn over though right?
voltage test at battery, if good, test voltage at starter from battery positive cable. if not good, test voltage drop over starter feed circuit. check voltage drop over starter ground circuit. if everything is good, you should probably replace the starter
HezaDelsol
12
Aug 19, 2012 08:38 PM
slowestek
Dec 26, 2009 10:36 PM
