Need Help:Engine sputters
Old Apr 8, 2009 | 06:55 PM
datflyboy's Avatar
Default Need Help:Engine sputters
did a engine swap on my boys 95' dx auto-d15, ran perfect all weekend. Now its beginning to sputter. Theres no CEL. i think its the gas but not 100% sure. He says he always goes to HESS for gas and filled the tank up with regular. Ever since the car stared sputtering here and there. Put 2 bottles of dry gas in. Still the same results. Dirty injector? idk im out of ideas.
Old Apr 8, 2009 | 06:57 PM
Former User's Avatar
Default Re: Need Help:Engine sputters
How do the plugs, cap, and rotor look? Have you resistance test the wires?
Old Apr 8, 2009 | 07:31 PM
datflyboy's Avatar
plugs n wires, dizzy cap n rotor are practically new. i recently did a tune-up on the old motor. swapped the parts over to the motor i just dropped in.
Old Apr 8, 2009 | 07:43 PM
datflyboy's Avatar
the CEL came on while driving for a while with this sputtering crap going on also
Old Apr 8, 2009 | 08:32 PM
Jump the service connector to see whether you can pull any codes (see forum CEL sticky).
Old Apr 9, 2009 | 12:22 PM
datflyboy's Avatar
no code because the CEL doesn't come on til u ride it for a while and the sputtering/shaking affect keeps happening.
Old Apr 9, 2009 | 12:43 PM
Does the sputtering happen while idling, driving, or both. More details might help.
Try to get the CEL code as it may focus your troubleshooting. I think a knowledgeable member (maybe 94EG8?) mentioned, for 5th generation Civics, a need to pull the car over when the CEL comes ON and to jump the connector with the engine still running. Can someone verify this?
Old Apr 10, 2009 | 09:09 AM
datflyboy's Avatar
its fine when idled, just when u start drivin it begins acting up.
Old Apr 10, 2009 | 11:23 AM
datflyboy's Avatar
bump for help
Old Apr 10, 2009 | 11:31 AM
1DayIllBFast's Avatar
I would do like RONJ said and as soon as it comes on pull over and check the CEL and go from there. Sorry not much help but you dont have much info until you can check the CEL
elnoyl
Honda Civic (2006 - 2015)
Aug 29, 2021 07:26 PM
dgarlotti
Feb 26, 2013 05:44 AM
bighoss77
Aug 15, 2012 06:54 AM
matt568
Feb 21, 2011 07:23 AM
BlackEJ6
Jan 13, 2006 03:02 PM
