What can I fit in here!?
my arm rest has 4 cutouts with blank plugs in them. The seat heater button goes there if I had leather... has anyone found something cool or useful to fit in?
these:
these:
1 Post
Re: What can I fit in here!?
I'm guessing the purpose of said switches is hidden
I had my ground to my indash wired to a toggle switch right there. so I can watch tv while driving. SMART huh lol no seriously that's really dumb
Ive made a bracket on the back side and made the panel slide in and out and have a push button on the back, so when parked and disabled it looks like stock, then get in and press it and it stays in about 1/8 of an inch and you can start the car.
H-T White Ops
Parking pole, half mast antenna, power headlights, heated seats (one switch per front seat) and coin slot.
The overseas five door Aerodeck (which IIRC uses a different center console) puts power window switches and a power window lock switch there.
Some cars that have been imported FROM a country that does not require a rear fog light TO a country that does require a rear fog light might install an Integra or Capa rear fog light and then put a rear fog light switch in the center console. This is not the factory placement for the rear fog light switch though. The factory placement for the switch is where the US cars have the cruise control or dimmer switch.
H-T White Ops
if you have aftermarket fogs, you can put the switch there.. although, It would be a bother to turn them on quickly if you had to. My switch is next to the steering wheel. I'm liking the push button start though! :D
No sir it is not. I broke my v tec pressure switch and never found a new one nowhere. so it was either no v tec or a switch untill i come across one. and yes it works. i hear it crack open. and at idle if i turn it on it sounds like a got a nasty *** cam in it.
i left my switch on one time and thought i had a vacuum leak. lol
now a thief knows how
