Starts and then dies slowly...any ideas
First post.
1999 LX Honda Civic 4 dr
The Problem
Couple of days ago noticed the car was harder and harder to start and then this recently. Car runs fine and then it slowly loses power (ie. Radio and Heater fan and then dash lights) and the car is like it’s missing gas or disconnecting the batteries and then it dies. Tried to start it and tick tick tick from right side under the dash and no or little power. Wait about abit and then starts again with full power and does this again. Once the car dies I can jump start it and runs fine for about 5 mins and then the problem again. Please help. I have an engine light code P1457 (Evap Emission Control System Leak Detected) but was told that this shouldn’t be it. Any ideas? thank you and looking forward to hearing some ideas.
The Problem
thanks....I have not tested the battery or alternator but why would it die and then start fine and full power after a couple of mins.. I am testing the battery tomorrow. Any other ideas. thx
im suggesting the alternator is just now going out, which is creating the inconsistency. you want to fix before it goes out completely and leaves you sitting on the side of the freeway.
if it was a fueling issue you probably would be throwing a code and your CEL would be on. your car would also run terrible if it was a bad pump or plugged filter or something of that sort.
I am throwing a code P1457 but it's not a fuel really. Maybe the car isn't ground somewhere. thanks for the replies. more ideas are welcomed.
You may have the common short circuit problem where an engine wire harness rubs on the intake manifold bracket. Is fuse 15 blown? Click here.
Hey RonJ@HT, Thanks for the diagram. I have gone under the car and the wires are taped and has a plastic casing. Looks good. I have also tested the battery and it's getting 11.75 or so and once the car is running the alternator is getting 8.4 and give it some gas and it goes down to 7's. The battery then is at 9.5 So, I think that the battery is running the car and the alternator is shorting out. Any ideas or your thoughts. thx
One possibility is that a fuse 15 TSB repair was already attempted without the short being completely fixed.
No, I am blowing a 7.5 fuse speed/alternator fuse. All codes are gone now but car can't start. Battery has a charge of 11.75 I am running out of ideas. thx
thanks for the quick reply. What do you mean by "problem described in the TSB" and the no start is "click click" under the right hand side dash and then nothing. It's like I don't have enough power to turn the engine over but the battery is at 11.50 or so. thx
The electrical short in the C115 wire harness described in the TSB that I posted a link to in post #7.
Clean the battery posts and connectors and then take your battery to a local auto parts store for testing and charging. If the battery is bad, you may need to replace it.
The C115 wire harness has two connections right under the fuel rail and not plugged into anything and nothing around to plug into. Maybe for some higher up models. The wires are alittle rough. You are suggesting that I tape or replace them? The battery is being charged tonight. thx around
Can you post photos of the uncoupled connectors near the fuel rail?
Study the diagram in the downloaded TSB carefully. The C115 wire harness is not under the fuel rail. It is under the intake manifold. To access, you need to put the front end on stands, crawl under the engine, and look in the area above the oil filter. You'll see the C115 connector there. When you find the damaged wires, repair them as described in the TSB.
koleah
Oct 2, 2005 02:33 PM
