Subs only work when on the radio, not when a CD is in??
Old Apr 8, 2009 | 04:00 PM
christian7750's Avatar
Default Subs only work when on the radio, not when a CD is in??
So when on the AM/FM radio my subs work, but when I switch to CD they turn off. Very confusing, I believe the only reason that causes this is the stereo is broken. Do you guys come to the same conclusion or do you have a solution? It is a Panasonic.
Old Apr 8, 2009 | 04:18 PM
dj-t's Avatar
Default Re: Subs only work when on the radio, not when a CD is in??
The only reason that I can think of right know is that you have the antenna and the remote lead mixed up. I think that there should be a blue and a blue/white switch it around and see if that works.
Old Apr 8, 2009 | 04:47 PM
Jturtle's Avatar
New User
X2 or some head units have the option to disable the subs. Does the amp actually turn off or do the subs just stop?
Old Apr 10, 2009 | 10:20 PM
twentyhurtz's Avatar
x3 this is the problem, you have the blue ant rem wire running to your amp instead of the amp turn on, remote wire, working at shops for years i have seen this TONS of times... its a common mistake...
Old Apr 11, 2009 | 08:31 PM
{AJ}'s Avatar
x4 Only because I fixed this same problem in someone's system a couple weeks ago.
Old Apr 12, 2009 | 02:14 PM
98civdx's Avatar
Master Detailer
friend of mine did it to,
just switch the wires and you should be fine.
Old Apr 12, 2009 | 08:23 PM
GetawayInMoscow's Avatar
made this mistake when i was in a hurry on my z06 too...happens to the best of us
Old Apr 13, 2009 | 12:25 PM
Hmm, that could have happened, definitely will check that today. Thanks a million and will let you know if it works
Old Apr 13, 2009 | 02:24 PM
Okay that was the problem, thanks.
mattkins91
Audio / Security / Video
Oct 30, 2008 06:38 PM
cbrf-3
Dec 2, 2004 07:41 AM
jlc-bigj
Jun 4, 2004 05:24 AM
only1crx
May 19, 2004 06:56 PM
jerm001
Apr 18, 2004 08:48 PM
