sub not working
Old Oct 29, 2008 | 06:54 PM
mattkins91's Avatar
Default sub not working
ok so my sub only works on the radio and when i put it on cd it doesnt work. what could be the problem?
Old Oct 29, 2008 | 08:11 PM
KRock459's Avatar
Default Re: sub not working (mattkins91)
You connected the power antenna lead to the amplifiers turn on lead, there should be a amp remote on the deck that remains powered up when the deck is on. Power antenna is usualy blue, amp turn on blue/white stripe
Kirk R
Old Oct 30, 2008 | 02:30 PM
mattkins91's Avatar
sorry but im confused
Old Oct 30, 2008 | 06:07 PM
KRock459's Avatar
Default Re: (mattkins91)
Did you just have the amp or system installed recently, or was the sub working on radio and CD and then stop? Is it a factory deck or aftermarket?
What I was refering to is the remote leads on the back of the head unit. Many decks have two leads, one for the power antenna, and one for the amplifier. The antenna lead (blue) supplies 12v + when the radio is on, the amplifier lead (blue/white stripe) has 12v + with radio and CD, or basicaly when the head unit is on to make easy.
If you have the antenna lead hooked up to the sub amp remote turn on lead, it will only work when the tuner or radio is on.
Kirk R
Modified by KRock459 at 7:18 PM 10/30/2008
Old Oct 30, 2008 | 06:29 PM
mattkins91's Avatar
i just installed it and it was only working on radio.
so are you saying i should wire it to the blue wire with the white stripe.
Old Oct 30, 2008 | 06:34 PM
KRock459's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattkins91 &raquo;</TD></TR><TR><TD CLASS="quote"> so are you saying i should wire it to the blue wire with the white stripe.</TD></TR></TABLE>
Yes, take the amp "remote" lead to the blue/white and not the blue, should solve your problem!
Kirk R
Old Oct 30, 2008 | 06:38 PM
mattkins91's Avatar
dude thanks alot man. thats what i thought the problem was but in my old car i had it hooked up to the blue and it worked.
christian7750
Audio / Security / Video
Apr 13, 2009 02:24 PM
dravesef
Jul 15, 2008 05:49 PM
jdmaek
Jan 9, 2005 11:15 PM
only1crx
May 19, 2004 06:56 PM
jerm001
Apr 18, 2004 08:48 PM
