set timing with out jumper
Old Apr 8, 2009 | 01:14 PM
turbo sol's Avatar
Default set timing with out jumper
what happens if I set my timing without the jumper installed (2 pin service connector).
with out it i am @ 16º btdc, but the car doenst start quite right, but it idles fine.
Old Apr 8, 2009 | 01:21 PM
TravisCadello's Avatar
Default Re: set timing with out jumper
never knew u needed to use a jumper?
Former User's Avatar
You need to jump the connector and the engine must be warm and idling to spec.
Jumping the connector prevents the ECU from automatically advancing the ignition timing so that you can properly set the base timing.
Old Apr 8, 2009 | 01:22 PM
turbo sol's Avatar
so my timing is off?
Old Apr 8, 2009 | 01:26 PM
It might be. Recheck the timing with the connector jumped. Are the plugs, wires, cap, and rotor in good shape?
Old Apr 8, 2009 | 01:30 PM
96 EX's Avatar
hmm, I dont think I've ever done this either and my car is running like garbage. Any pics on what the actual service connector looks like? I'm going to search in the meantime until a reply. Thanks in advance
Old Apr 8, 2009 | 01:46 PM
turbo sol's Avatar
its the same plug you use to check CEL codes.
http://www.team-integra.net/sections...p?ArticleID=34
It's the same service connector used to pull CEL codes (see forum CEL sticky). (edit: or post above)
Old Apr 8, 2009 | 02:07 PM
96 EX's Avatar
Doh! I've probably looked over that thing 115643210 times. Thanks for the pics! Ok now I know why I could never find it, it was hid behind the ECU, so I take this plug out and jump it like in the pictures. This in turn should give me the codes for my random misfiring. At this point would I plug it back in for it to recognize that I re-set the timing??
raverx3m
Apr 9, 2012 09:15 AM
turbo-crx
May 18, 2008 02:13 PM
civic j
Aug 17, 2007 08:10 AM
smash fascism
17
Sep 14, 2005 07:02 AM
Nextelbuddy
Mar 30, 2004 10:09 AM
