How can I tell if this motor is ok
Old Apr 8, 2009 | 07:03 AM
OrangeTeggy's Avatar
Default How can I tell if this motor is ok
I am looking at a 96 Integra. The motor is a b18c1 the kid says it wasnt smoking or burning any oil before it was damaged.(windows were all totally broke out of it) . The tranny was still in gear and got pulled onto a trailer so it could be towed. So he took out the tranny and tried fixing it. Now I cant see if it starts because the radiator isnt hooked up and something with the clutch that isnt allowing it to be pushed in too start. My question is how can I tell if the motor is still usable or able to be pulled and sold without hearing it start.
Old Apr 8, 2009 | 07:08 AM
Top Speed's Avatar
Default Re: How can I tell if this motor is ok
leak down test
Old Apr 8, 2009 | 08:03 AM
Leak down test
Can you explain that for me or give me somewhere I can look it up?
Old Apr 8, 2009 | 08:28 AM
99JDMHATCH's Avatar
its similar to a compression test but more in depth. if it was me i would look else where. how much does he want for it?
http://www.c-speedracing.com/howto.php. thats a link that will help u with learning what a leak down test is and how to actually do it yourself.
Old Apr 8, 2009 | 10:55 AM
its a really good deal less then a grand
Old Apr 8, 2009 | 04:48 PM
99JDMHATCH's Avatar
not bad but definetly do a compression check before buying
Old Apr 8, 2009 | 07:40 PM
sixfourkiller's Avatar
leak down test would be your best bet if not at least a compression test but dont know the number it should be but i think for that its from 180 to 210 someone correct me if im wrong
Old Apr 8, 2009 | 08:55 PM
papaboy's Avatar
agree with everyone else leak down test it and have a mechanic (Honda preferred) give it a look over as well the know the weak points to keep your eyes out for.
Old Apr 8, 2009 | 08:58 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Compression/leakdown test would do the job.
Old Apr 8, 2009 | 09:17 PM
bigbadbp7's Avatar
ahh he can do that if the motor could turn over with the starter but it doenst sound like thats going to happen
Old Apr 8, 2009 | 10:02 PM
409 IYCM's Avatar
It just goes to show everyone on HT will just jump on the band wagon... and not even read the guys actual question for themself.
"My question is how can I tell if the motor is still usable or able to be pulled and sold without hearing it start. "
You cant. The car needs to be able to run to perform a leakdown test.
Old Apr 9, 2009 | 02:33 AM
99JDMHATCH's Avatar
you are right. to be exact it is 200 but the cylinders shouldnt vary any more or less then 20 aka more then 10%
thanks 409. come accross alot of ppl that just want to bash but not help.
Old Apr 9, 2009 | 06:45 AM
I went too look at this car, and the windows are busted out of it and it looks like ****. But theres a lot of good parts still left on there. But he told me he pulled the transmission to fix it but he didnt put it back in correctly because the clutch wont engage too start it
Old Apr 9, 2009 | 06:50 AM
99JDMHATCH's Avatar
honestly sounds like your bent on buying the car. personally i'd go else where and just by hatch with a gsr already in it. how u plan on getting it home?
Old Apr 9, 2009 | 10:12 AM
I plan on puttin it on a trailer and taken it home
Old Apr 9, 2009 | 10:29 AM
sp00ledbseries's Avatar
I would do a compression test on it. You can still do it just spin the crank pulley. If the test was good I would buy it. JMO
Old Apr 9, 2009 | 06:29 PM
bigbadbp7's Avatar
"Now I cant see if it starts because the radiator isnt hooked up and something with the clutch that isnt allowing it to be pushed in too start"
NOT jumping on no band wagon just sayihg it wont work!
katoeh2o
Jan 9, 2008 11:49 AM
1fastvtec
Apr 20, 2007 06:29 PM
stripes777
Mar 17, 2004 08:34 AM
JDMEMM
Oct 21, 2002 10:56 PM
4potnick
Jul 23, 2002 04:24 PM
