got a da
Old Mar 29, 2009 | 07:34 PM
lsb18_hatch's Avatar
Default got a da
just got a da integra tonite but the motor is shot...and its automatic i was wondering i have a 1990 honda civic hatch with a b18 in it to swap it out into the integra and convert it to manual wat else will i need.
Old Mar 30, 2009 | 06:22 AM
Default Re: got a da
anybody.
Old Mar 30, 2009 | 06:43 AM
Old Mar 30, 2009 | 07:07 AM
JDMJoeHick's Avatar
OEM Clutch pedal assembly, OEM Master cylinder and prob a stock Manual ECU for that B18. Axles and drivetrain can prob remain the same unless you wanna upgrade.
Old Mar 30, 2009 | 07:29 AM
i think i can use the ecu outta the civic right cuz its b18.
Old Mar 30, 2009 | 07:34 AM
JDMJoeHick's Avatar
Right that slipped my mind... but yes you should be just about good to go just find a junk DA and get the assembly off of it. I mean your just doing a stock setup so it'll have everything you need for the picking. You know your mounts will work because it already had a B18 in it.
Old Mar 30, 2009 | 07:58 AM
thanks man.
Old Mar 30, 2009 | 08:01 AM
JDMJoeHick's Avatar
Good luck with the swap buddy! Take it easy.
Old Mar 30, 2009 | 11:17 AM
ALLxMOTOR EG's Avatar
Vietnamese!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-my-auto-manual-swap-pics-56k-no-no-2090074/
Old Mar 31, 2009 | 06:25 PM
DA9_Gurl's Avatar
your going to need the auto to manual tranny mount as well..
Along with a new starter..
Also, when you drilling the hole for the cable make sure you double check the exact spot otherwise you might have issue's with the cable being to short. When your putting the cable through the hole, this might sound real stupid, but make sure you put the WHOLE end of the cable through so the rubber blockoff thing if resting flat against the firewall. I learned the hard way that, that could make a huge difference lol
I converted mine 2 years ago so if you need any advice hit me up.
Old Apr 3, 2009 | 02:50 PM
jdmjoka's Avatar
DB squad #282
just keep that hatch fool
Old Apr 3, 2009 | 04:57 PM
idk
Old Apr 7, 2009 | 10:24 AM
AWJDMDA9's Avatar
5 speed cable tranny 90-91 or 92-93 depending on clutch kit and flywheel
clutch,pressure plate, flywheel,pilot bearing, throwout bearing
Flywheel bolts from 5 speed, pressure plate bolts
shift linkege and hardware
Auto to 5 speed mount from Innovative mounts
5 speed computer
Gauge cluster ( optional)
Shifter and hardware
Pedal assembly_ depeding if you have crusie control or not the RS pedal assembly does not have the tab for the cruise cable to fit on to.
Old Apr 7, 2009 | 10:32 AM
HondaTom87's Avatar
I got a manuel pr4 ecu for sale if you want it? lol
but I love the car reminds me of the day I bought my DA looks exactly the same too lol
Old Apr 9, 2009 | 06:50 PM
ima keep the hatch haha boost this summer;|
k20zfg2
Jan 14, 2011 06:26 AM
Toolman
May 17, 2005 08:18 AM
deeeffache
Sep 10, 2002 02:29 AM
Aceman64
11
Dec 27, 2001 11:56 AM
