Which bondo is best?
I'm new to body work and am prepping a Del Sol I just picked up for paint. There's some deep cuts on the bumpers and I also need to smooth out the fenders which I flared. I picked up some Bondo Premium but is this the best stuff to use? Will it adhere to the plastic bumpers and is it a good dent filler or should I be using something that's not as thick?
yeah i use evercoat too... either their zgrip or rage gold or rage extreme
pricey tho considering u can still achieve the same quality almost, with bondo brand from 3m at autozone. even tho i hate that sh*t haha
Thanks for all the help guys, I really appreciate that. It seems like it's mostly just personal preference. Bondo I've used before is thick and may take more to sand down, but it seems to hold up well. I just didn't want to start using it and then later find out I used a totally wrong product, or something that took me way longer then it should have. Kind of like using finger putty on screw holes in drywall instead of on baseboard pin nails like it's meant for.
just remember... bondo works best for dents that aren't more then 3mm deep... meaning if u just so happen to have dents... pull them first as much as you can be4 u fill them
sure it will take longer to get dry.sandable area, but if it gives you 5 more minutes of use its worth it
deLs0L93
Aug 15, 2013 05:39 PM
raverx3m
Paint and Body
15
Feb 2, 2011 03:10 PM
Jhonny Ricer
Sep 9, 2006 07:24 PM
