Removing climate control
Old Apr 5, 2009 | 11:08 AM
D Grade's Avatar
Default Removing climate control
Im replacing my A/C CC unit with a non A/C unit after removing my A/C all together. Whats the easiest step by step way to remove the climate control out of an EG? Tried looking for a write up but couldnt find one.
Old Apr 5, 2009 | 11:41 AM
The_Honda_Guy's Avatar
Default Re: Removing climate control
You need to pull the dash out to remove it all.
Old Apr 5, 2009 | 12:39 PM
honda.lioness's Avatar
There might be a writeup out there, but I got by using four resources the first time I pulled the CCU on my 93 Civic:
1. http://media.honda.co.uk/car/owner/m...s/CivicManual/ (UK manual site links are allowed, last I heard a few months ago).
2. the free online manual specific to your Civic at autozone.com
3. Parts drawings at www.bkhondaparts.com
4. practiced on one at the wrecking yard.
For the manuals, you will likely need to work with a few sections. E.g. the radio removal section and the CCU removal section. Once you know which screws/bolts to look for and what cables to disconnect, it is not too difficult. First time ever CCU removal is annoying for sure, though.
Old Apr 5, 2009 | 01:56 PM
ALLxMOTOR EG's Avatar
Vietnamese!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-take-out-92-95-civic-climate-control-2500000/
Old Apr 5, 2009 | 02:36 PM
94EG8's Avatar
Seagull Management
Or you could just remove the A/C button and replace it with the block off plate, the climate control units themselves are identical.
Old Apr 5, 2009 | 03:34 PM
D Grade's Avatar
I figured that much, however my stock CC has a burnt out light blub so it needs to come out anyways.
Thanks for the links, Ill check em out.
turboedsupe
Feb 23, 2009 06:58 PM
jdmsir4dr
Nov 20, 2008 08:15 AM
TEAM EoR
Apr 12, 2008 11:26 AM
ner0x
Jun 23, 2005 07:17 PM
Trbospnkr
Jan 29, 2004 04:24 PM
