help rpm cut off
i swapped a ls into my 98 civic and everything is fine checked the codes and the ones that popped up had nothing to do with it just evap but when i rev the car or drive it it cuts out around 2500 or 3000 rpm not sure dont have a tach but its around there
has this happened to you before or do you know what it is thanks
is it only 2-3k? or after 2k up it does it?
Maybe a Simple Tune Up Is Needed. Double check all sensors. maybe the TPS Throttle Position sensor needs to be adjusted or replaced.
if it just needs to be adjusted no it wont. and now you say its like a rev limited i know what your talking about. my brother had this same problem and we took the distributor apart and seen metal shaving inside it so we replaced it and it was fixed. its either that or your ecu is in safe mode. which i believe means it found somthing wrong and wont let it rev high. but since u dont have a CEL then id check the dizzy.
PINKS
24
Dec 1, 2006 06:07 AM
JasonST
Aug 24, 2006 05:08 PM
