Motorola 2.5 Bar Map Sensor! Need Help!
Okay so i'm almost complete on my turbo project all i need left to do is wire up my Motorola 2.5 Bar Map Sensor. I have it wired up.. But i can't figure out what vacuum line to hook up too it. I've heard i shouldn't T a vacumm line off of it, is this true? I tried to use search and can't find anything! Does anybody have a DIY Website or is anyone running one of these that can tell me how to hook it up? Thanks in advance!
Heres the website, The directions don't say much...
http://www.xenocron.com/motorola-25-...kit-p-194.html
I installed mine into the factory o.e.m. case so it just bolts up like normal, isn't really that hard to do and makes it simple. But any strong vacuum source will work. I'd recommend one straight of the intake manifold if you're able with nothing else feeding from it, but depending on what intake manifold it is, you might not have any extra fittings. If thats the case, I'd recommend a vacuum block with a short line to the intake manni to feed the other things and that will open a port directly off the intake manifold.
tempsohc
Jun 19, 2011 06:06 PM
