About going to a CA Ref
i got a ticket for 27150 (exhaust) & 27156 (mod emission) and so now im suppose to go to the ref. my question for those who have gone to the ref is: do they pop your hood?
i have a gsr in an ek and i was going to put a stock cat and exhaust on and get tested but if they pop the hood then there's no point. lemme know thanks
i got the same ticket, but i had no choice and couldnt go because ref was down at the time.
i just waited for my court date, paid my fine, and i was on my way again.
still riddin dirtaay! :D
lol.
ffck chp!
lol.
ffck chp!
ive had my car bar'd but have never been to the ref for a ticket. when i went there was a guy with a sti who had gotten a muffler ticket. i didnt get there when they started the test but from what i saw they didnt pop his hood.
They pop ur hood and see what motor you have so they can test the db of the exhaust. the rpm they hold your car at depends on the motor. I had a b16 in my hatch and I got and exhaust ticket. The ref said u have a b16 and we have to test the car with delsol specs. So they held the rpm at 5500 with a db instrument about a foot away from my tail pipe. They did not use the dyno to test db of the my exhaust. I did it twice and it was the same procedures. But since you got a smog device violation you will have to smog your car. Gl on that though.
What year is your car and motor? If the GSR is older than the car, then you are SOoL. When I went to the ref to get my car certified, obviously they popped my hood to make sure all of the emissions components were installed.
if u go to the ref then ur gonna need to pass everything n make ur motor legal and a Bar sticker..u can either pay the fine which is gonna be like $300+ or make ur motor legal meaning change everything to stock and hook up all ur evap stuff
that sucks man. i say you just get the motor bar'd youll be happy in the end.
For the modified exhaust they dont say anything about your engine they check your water and oil and then sound test it.. but since you got a modified emissions violations they will inspect the car and do a smog on it
Oh also if you decide not to go to the referee you just have to pay the fine and keep rolling. also if you pay the fine you will have to smog your car at a test only station for next year.
Correct me if I'm wrong, but isn't an aftermarket exhaust a "mod emission?"
I know that the exhaust is for sound reduction and doesn't have an affect on emissions, but doesn't the vehicle code consider the exhaust part of the emission system, and thus, if modified, it's a modified emission system?
I have a 96 ek with 96 jdm gsr. Does anybody know if you can BAR a JDM motor?!?
https://honda-tech.com/forums/showth...t%3Bjdm+type+r
Short answer, "yes it can." Not exactly the same, (JDM TypeR into a USDM Teg) but it's an answer.
sure can, just got my JDM type R BAR'd on friday..passed with very nice numbers...just make sure your car has all the USDM smog stuff on it, and is stock or has CARB legal stuff under the hood...header, intake..and you may have to run the USDM ECU...i did..took about 30 mins... got my sticker $8.25 just call and make a reff apt
HotboxedTypeR
Dec 22, 2007 08:46 AM
