Oil return line touching manifold, heat sleeve??
I'm using a -10 braided oil return line.
It touches on the manifold and I noticed that it started leaving little burn marks on the line.
What kind of sleeve can I use to protect the line from ruining?
I purchased the DEI Heat Sheath Protective Sleeve, but I don't feel confident that this will hold since it touches on the manifold. Is there anything else? Has anyone had a similar problem before?
I've got so many heat problem I don't know where to start. I wrapped my line with the DEI Cool Tape (1500 deg), and then re-wrapped it with a fiberglass exhaust wrap, then wrapped another 2-3 layers of the cool tape where the line actually makes contact with anything. The heat sheath you show above is only good up to 500 degs.
Cool Tape:
http://www.designengineering.com/pro...sp?m=sp&pid=30
If your seeing burn marks on the line, keep an eye out for any oil leaks that may indicate that the inner liner material has been compromised.
Cool Tape:
Bump cause my -3an feed is contacting my manifold. I jammed a piece of heat wrap material between the manifold and the line cause its a greddy manifold and cant really be wrapped.
Im thinking it would be hard to ruin the inner tube with oil running through it to cool but I have a long road trip in a few days and I really cant have this bursting on me.
depending how much touches I would use a DEI Protect-a-boot thats used with spark plug wires, Its rated at 1200 deg direct continuous heat. but its only 6" on top of the heat sheath.
Topdawgg
May 25, 2007 08:20 AM
BLKCRX
Dec 20, 2002 05:41 AM
