Stainless return line.. Would the rubber inside melt....
Old May 25, 2007 | 06:26 AM
Topdawgg's Avatar
Default Stainless return line.. Would the rubber inside melt....
If it touched my manifold slightly?
I know the whole point of the stainless return line is to withstand heat, but if the metal from the line is touching the manifold, would It heat the rubber inside up so much that it could melt it...
just a stupid question.... Im really not sure... I figured it could
Old May 25, 2007 | 06:36 AM
HiProfile's Avatar
Default Re: Stainless return line.. Would the rubber inside melt.... (Topdawgg)
It could, but I doubt it will, as the oil flow would help cool it. You will want to let it cool down before you turn it off, otherwise there will be no oil running through it to cool it. You could also buy stainless braid with a teflon liner, its actually cheap at mcmaster.com, and can take temps much higher than rubber-lined return lines.
Old May 25, 2007 | 06:48 AM
Topdawgg's Avatar
i was gonna just heat wrap a small section of my manifold, but it its not an issue i wont
Old May 25, 2007 | 06:52 AM
Dartanian's Avatar
Default Re: (Topdawgg)
Mine touches my DP. Been running it for 6 months+ with no problems.
Old May 25, 2007 | 07:00 AM
Topdawgg's Avatar
good to know
Old May 25, 2007 | 07:52 AM
Dunc's Avatar
BCICAN
Default Re: Stainless return line.. Would the rubber inside melt.... (HiProfile)
Think of it like this: If your bare rubber line would melt if touching the manifold, then sure the stainless gives some extra protection <U>temporarily</U>. However, what is going to happen after the stainless has been touching the manifold for so long that the stainless is the same temperature as the manifold.......the rubber will not like life.
Old May 25, 2007 | 08:20 AM
IN VTEC's Avatar
I ran Aeroquip AQP for PCV E-vac for a few months and when I removed the line, the first 3 inches was hard, crusty, and brittle.
justYncredible
Jul 16, 2012 10:22 AM
the_iceman
Sep 7, 2009 09:20 AM
R.A.T.
Aug 16, 2009 07:07 AM
BLKCRX
Dec 20, 2002 05:41 AM
