USDM Head , JDM Block
Old Apr 1, 2009 | 05:57 PM
SniperRCivic's Avatar
Icon6 USDM Head , JDM Block
ok so i saved up and got myself a JDM 97 GSR Changeover and its a OBD2 woohoo, i had it installed (no garage) and after that i find out that jap emissions are diff. so its a OBD2 that wont pass US emissions. So my question is if i have a USDM Head & ECU put on a JDM block what other sensors would have to be add/replace
thanks for the help
Old Apr 6, 2009 | 09:48 AM
Default Re: USDM Head , JDM Block
anyone?
Old Apr 6, 2009 | 09:51 AM
oddeb707's Avatar
I'm pretty sure all you need is the IM and ECU. So you should be ok.
Old Apr 6, 2009 | 10:03 AM
B18CivicEJ8's Avatar
thanks for the help
Try this:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-diy-how-convert-jdm-intake-manifold-usdm-specs-smog-ref-859796/
I know it says ITR, but use a USDM GSR manifold and the instructions are the same.
Old Apr 6, 2009 | 10:11 AM
mortificationrock's Avatar
Well from what i know the JDM blocks dont have some sensor that the USDM does. I forgot what its called though. And something about the pump.
Old Apr 6, 2009 | 10:13 AM
fireblaze2k1's Avatar
Should be just intake manifold, and you should be able to find that other sensor. What year is your civic?
Old Apr 6, 2009 | 10:19 AM
turbo97coupe's Avatar
JDM motors do not have the Ckf sensor , its the sensor that is bolted to the oil pump on OBD2 engines
Old Apr 6, 2009 | 10:22 AM
http://ff-squad.com/wp/?p=309
That's the fix.
Old Apr 6, 2009 | 10:27 AM
yep , i just went thru the Ckf sensor issue
Old Aug 2, 2009 | 11:40 AM
sorry to not be on as much but i wanted to thank all that helped .. havent been able to do anything, workin over 60 hrs a week but again thanks to all
benchmade
Northern California (Sales)
Jul 28, 2009 01:54 AM
972drcordex
Feb 22, 2006 07:46 PM
972drcordex
Feb 22, 2006 02:08 PM
saer
Aug 29, 2004 09:08 AM
