d16z6 zex cam start up timing.
Old Apr 1, 2009 | 03:01 PM
turbo sol's Avatar
Default d16z6 zex cam start up timing.
I have a vitara z6 with eagle rods and a zex cam. it starts pretty hard.
i didn't know what you guys are using for timing setting to get it to start. It idles good and runs fine, just starts when i hold down the pedal.
are you just setting it to 16º btdc?
any adjustment to the timing through the engine management?
I'm going back to the tuner on sat. I just want to do some research first.
thanks guys.
Old Apr 1, 2009 | 06:06 PM
D16SohcVtec's Avatar
Default Re: d16z6 zex cam start up timing.
Just set the ignition timing to 16 degrees. Sounds like a starting issue my buddy had. Are you using DSM 450s?
Old Apr 1, 2009 | 06:43 PM
turbo sol's Avatar
precision 450's
what did your buddy end up doing?
Old Apr 1, 2009 | 08:58 PM
Originally Posted by turbo sol
precision 450's
What fuel management are you using? You should be able to trim the start up fuel, as 450 will allow more fuel and might temp flood the chambers causing a mild hard start. In my buddy case. He was using used DSM 450's and his car would have hard starts. It would have to crank over a few times before it started. He ran it like that for a few years until recently he finally through a CEL for fuel injectors. Took a stethoscope? And listened to every single one of this injectors. One of them ended up being bad. He threw in his stock injectors and started right up. Not saying this could be your issue, but something to look into.
Old Apr 2, 2009 | 07:08 AM
turbo sol's Avatar
Thanks!
Slen17
24
Jun 28, 2012 09:10 PM
the_dxB16
Dec 25, 2008 12:29 PM
hfhondacrx
Sep 19, 2007 05:26 AM
LoudLX
Nov 8, 2004 03:54 PM
low-tech assassin
Nov 3, 2003 06:50 PM
