D16Z6 Ignition and Cam timing settings
D16Z6,
Ignition timing- full advance
Cam timing- 14* advanced!!!
I didnt set it like this but that is the way it sits. It pulls pretty strong but i am wondering if it is slower than it could be with better settings. ive got i/h/e, cam gear, pulleys, and fpr.
Modified by low-tech assassin at 2:32 PM 11/3/2003
D Tranny Guru
Re: D16Z6 Ignition and Cam timing settings (low-tech assassin)
you car is focked up!!!!!!!!
Timing belt is atleast one tooth off, maybe 2 teeth!!!!!!
You want 3 degrees retard on the cam gear, 19 degress BTDC on the ignition timing.
Re: D16Z6 Ignition and Cam timing settings (Mista Bone)
im running 93 octane. Thanks alot bone!! Can you tell me how i should go about setting it to the right tooth? It's wierd that it is so far out because the car is runnin great.
TranspeedMotorsports
11-12-2006 09:11 AM
