brake master cylinder ?
hey how can i tell if my master cylinder is bad or my brake lines are bad. i checked all the brake lines behind the wheels and no leaks. my brake pedal is really spongey and goes almost to the floor. also when i filled up the master cylinder with fluid, it drained out in about a month. thanks
ok so i saw this thing on a thread i found searching. i did #2 of the functional test and passed. i also did #1 and #2 of the leak test and also passed. i dont know if this information helps but ya.
im gonna check for fluid in between the mc and the booster right now. thanks
i checked and nothing between the MC and booster. its all good. maybe i need to re-check brake lines behind the wheels.
since all the fluid leaked out, if i fill it up and have someone pump the brakes while i check the lines, fluid should start to leak out every time the brake is depressed right?
i just went through this, check and see if you have a puddle of brake flluid under you backseat, if you do then one of the llines coming from the prop valve to the rubber lines in back broke
