Brake Problems
Old Sep 8, 2005 | 07:21 AM
Tenners's Avatar
Default Brake Problems
I wonder if any of you might know what's wrong with my ride here.
I have a '94 Accord. 5 speed EX model.
Every time I press my brake pedal down, it slowly goes further and further down as though the brake line is losing pressure....and it goes all the way down to the floor.
Any help would be great.
Thanks,
T.
Old Sep 8, 2005 | 07:34 AM
LOGICx420x's Avatar
Default Re: Brake Problems (Tenners)
I would start with your master cylinder, if not check your brake booster, but i'm pretty sure it's you master cylinder...
Old Sep 8, 2005 | 08:08 AM
Tenners's Avatar
Default Re: Brake Problems (LOGICx420x)
Exactly how much do you think that would cost to fix???
Old Sep 8, 2005 | 09:34 AM
P_Adams's Avatar
If the system is not loosing fluid, look no furthur than your Master cylinder.
You're going to have to not only replace the Master Cylinder, but have the brake system inspected and flushed with new brake fluid.
Your master Cylinder failed because the brake fluid was never changed, and absorbed water over the years to the point that it started rusting metal bits.
Check out these guys:
http://www.secureleadercom.com...block
P
Old Sep 8, 2005 | 10:13 AM
Elvis1977's Avatar
Also, check wheel cylinders for leakage if you have drum brakes.
Old Sep 8, 2005 | 10:23 AM
blakezilla06's Avatar
Default Re: Brake Problems (Elvis1977)
Not exactly I had the same problem! Brake Fluid is all you need just some slippage! Put some brake fluid in and pump the brake pedal until extremely tight!
Old Sep 8, 2005 | 11:16 AM
deserthonda's Avatar
use a honda part ... master is around 130-140 dollars, brake fluid u can get at autozone 2-3 dollars ,,,if a shop does the work depends on their hourly rate but it should be no more than 70-100 dollars
Old Sep 8, 2005 | 11:17 AM
P_Adams's Avatar
Default Re: Brake Problems (gsrdude01)
Directed to gsrdude01:
[QUOTE]
"Not exactly I had the same problem! Brake Fluid is all you need just some slippage! Put some brake fluid in and pump the brake pedal until extremely tight!"
F/D LOL ...... And I'll sit back and watch for your obituary.
Is this MAGIC brake fluid you're proposing? Perhaps a bottle of "Mechanic inna Can"??
Old Sep 8, 2005 | 11:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrdude01 &raquo;</TD></TR><TR><TD CLASS="quote"> Not exactly I had the same problem! Brake Fluid is all you need just some slippage! Put some brake fluid in and pump the brake pedal until extremely tight!</TD></TR></TABLE>
LOL LOL. man what are you doing??? that is the boogiest advice i have ever heard SLIPPAGE?????
yo amigo do as everyone suggested replace brake master...
and P_ ole buddy do those mechanic ina can realy work ???
Old Sep 8, 2005 | 01:18 PM
Tenners's Avatar
Default Re: Brake Problems (deserthonda)
Thanks peeps,
I really should get on that ASAP 'cause it's not gonna help itself. hmm...I'm not so sure about that "add brake fluid" and pray move...maybe you had a slightly different problem.
Thanks for all the help though folks,
T.
Old Sep 8, 2005 | 01:19 PM
P_Adams's Avatar
Yeh, that and the STP sticker on the window.
You've a better chance of the car fixing itself.
Pete
Old Sep 9, 2005 | 06:45 PM
BLKFLSH's Avatar
Default Re: Brake Problems (P_Adams)
"Mechanic inna Can"?? I like that one, can I use it? Ha Ha.
another eg
Sep 1, 2015 04:31 PM
ribal_gh
11
Apr 30, 2013 04:24 AM
patrickstar
Apr 4, 2009 07:57 PM
LIVE 2 DRAG
Feb 6, 2006 06:27 PM
MrEg
Sep 22, 2003 04:49 PM
