B16a ???
Old Apr 1, 2009 | 08:41 AM
toolbox21's Avatar
Icon2 B16a ???
I got a 1991 CRX Si, with a JDM OBD0 B16A Swap, Its Converted To OBD1 with a jdm p30 ecu. i have a boggin problem at lower rpm's it does its sometimes and seem to do it more the longer the car is running its real hesitant and very little throttle response, but when it hits vtec it pulls hard like it should, ive changes the plugs, tps and ohmed to spec, getting fuel, and checked all grounds. the only thing i havent done is try another dizzy?, and ive heard something about using a wide band o2 sensor. any suggestion would be great i cant stand the boggyness?
Old Apr 1, 2009 | 09:01 AM
ef-hatchcrap's Avatar
Default Re: B16a ???
Change your vtec fluid.
Old Apr 1, 2009 | 09:32 AM
aaronhume's Avatar
lol...vtec fluid should be full. check timing
Old Apr 1, 2009 | 09:37 AM
Timings good I set it with a light I thinks it the computer
Old Apr 1, 2009 | 09:49 AM
toolbox21's Avatar
Dont think its the ECU it ran the same way with your ECU
Old Apr 1, 2009 | 11:00 AM
Take swap out, then burn the car and get a new one.
Old Apr 1, 2009 | 12:31 PM
destin1988's Avatar
New User
check your fuel pump and your fuel injectors and the o2 sensors
Old Apr 1, 2009 | 12:39 PM
Dark_Teg's Avatar
Did you jump the service connector to set the timing?
Old Apr 1, 2009 | 12:57 PM
I heart My EF Sedan's Avatar
also try cleaning your IACV
Old Apr 1, 2009 | 02:35 PM
toolbox21's Avatar
what do you mean jump the service connector
slimshady101
Mar 2, 2012 01:32 PM
hondateg10
Mar 5, 2007 06:06 AM
Rywire
20
Dec 10, 2005 08:41 AM
DreamOfTheFlood
15
Nov 26, 2005 05:13 PM
DohcVtecCrx
Feb 27, 2004 06:41 PM
