Help!!!!help!!!!!help!!!!!fuel pump????????
what could not make the fuel pump work...like the main relay...anything other suggestions would be appreciated!!!!!!!!!!!!
ive been having a similar problem in my d15b7 swapped 97 hx ek... maybe 1/30 times the fuel pump doesnt click on and i have to kick the **** out of the fuse box to get it come on...after researching a little bit ive found that it either could be faulty connection or a bad relay...test the relay before you go out and buy a new one...i saw the way to test it somewhere...
What car??
The fuse on my EK blew. Its a 15AMP next to the battery in the engine bay. I belive its labeled "F I EM" or something like that.
If you want to see if fuel pump works, remove it. Take off cover with Philips, disconnect the plugs. Remove with 10mm. Then attach a wire to the positive and negative, then the opposing ends to the battery. If it turns on then you're good to go. Its your relay or your fuse.
rastakid
Dec 17, 2018 06:16 PM
b16_coupe
11
Dec 22, 2013 11:39 PM
