stepping on gas to start car...help!!
Old Mar 31, 2009 | 04:40 PM
sevenfc's Avatar
Default stepping on gas to start car...help!!
so everytime i need to start my car, i always have to gas it to start otherwise my car will die...i dont have an fitv to clean since its an obd2 gsr head but i did clean my iacv and its still the same...anything else that can cause it to start like this...im really stumped...
Old Mar 31, 2009 | 05:22 PM
Swansen's Avatar
Default Re: stepping on gas to start car...help!!
http://answers.yahoo.com/question/in...2101530AAFh8Uk
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/why-do-i-have-press-gas-start-car-2509319/
Old Mar 31, 2009 | 06:11 PM
Jimster480's Avatar
are you misfiring? This was happening to me the other day and the car was misfiring because of a broken wire on my OBD2-OBD1 Conversion harness. Try unplugging the IACV and starting the car. It should idle very low.
Old Mar 31, 2009 | 06:12 PM
Former User's Avatar
Is the CEL ON?
A bad IACV seems most likely.
Have you tried replacing the air filter or adjusting the idle screw on the throttle body?
Old Mar 31, 2009 | 06:14 PM
sevenfc's Avatar
thanks for the threads but it could not really help...my motor just recently got rebuilt which is an ls block with a gsr head...rite now its still an obd2 running on p2t si b16 ecu...could it be that i need to convert to obd1 and run a p28 with a good basemap for now since i kno getting my car tune will b pretty spendy...
Old Mar 31, 2009 | 06:17 PM
sevenfc's Avatar
i do have a cel but its for the second 02 sensor and knock sensor...but when i cleaned my iacv, i tested it with power and ground to the pins from the valve and it would click...wouldnt that tell me that its working...the air filter is new which i just bought and as far as the throttle screw, how do i adjust it...which way do i turn it too and how much..does the iacv have to be unplugged to set it..
Old Mar 31, 2009 | 06:44 PM
Jimster480's Avatar
the iacv doesnt have to be unplugged. You turn it clockwise for lower, counter clockwise for higher. You need a flat screwdriver to do this.
Old Mar 31, 2009 | 06:51 PM
Swansen's Avatar
Well, the ECU could be causing the issue, the second O2 sensor could also be causing your problems. As far as the knock sensor goes, i find it hard to believe its failed, its a rock, like a crystal, there isn't much to fail there.
Old Mar 31, 2009 | 06:55 PM
sevenfc's Avatar
ya ima soon convert to obd1 with p28 with a basemap from pherable tuning...also im pretty sure obd1 doesnt look for knock sensor and the second o2 sensor...
civicef990
Nov 21, 2011 04:14 PM
smokinloc
Mar 8, 2010 01:39 PM
sevenfc
Mar 18, 2009 03:26 AM
asianspeed
Dec 6, 2004 04:46 PM
civicmug
11
Aug 23, 2004 10:48 PM
