Need help with serious vacuum problem
Old Mar 31, 2009 | 12:10 PM
slob20ef's Avatar
Default Need help with serious vacuum problem
ok so when i start my ls vtec it hunts ide from 1000-1500 rpm. When i run it down the road its fine, but if you let off the gas and let it come down to 1500 it will try to hunt idle again. Just wondering what vacuum lines would cause this. I took out the black canister that runs the vacuum lines, but i know the brake booster, FPR, evap to the throttle body is hooked up, just wondering what other vacuum lines would cause this?
Old Mar 31, 2009 | 12:24 PM
slob20ef's Avatar
Default Re: Need help with serious vacuum problem
can anyone help?
Old Mar 31, 2009 | 12:38 PM
Former User's Avatar
Could also be a leak from the throttle body or IM gasket.
Is the CEL ON? Have you cleaned the IACV? Do you have a FITV? Is the coolant level low? Have you tried bleeding the cooling system?
Old Mar 31, 2009 | 12:45 PM
slob20ef's Avatar
CEL is on, but only for 02 sensor not being hooked uo
also the coolant is full and the IM and TB are tight
i have not cleaned the IACV and dont know if i have
a FITV, and i did bleed the cooling system. its a gsr head
btw. Thanks. Im almost positive its vacuum. car runs fine
when u keep it above 1500rpm
Old Mar 31, 2009 | 01:35 PM
slob20ef's Avatar
bump
Old Mar 31, 2009 | 01:39 PM
If you cover the top of the throttle body with your hand while the engine is idling, can you kill the engine?
Try cleaning the IACV. Does the idle speed change by covering the IACV port in the throttle body with your finger?
Here's a link for the FITV.
Old Mar 31, 2009 | 01:43 PM
dumpsterbaby's Avatar
get a can of brake cleaner, with the engine running spray brake cleaner over any part where there may be a leak, if the engine bogs down youve found your leak
Old Mar 31, 2009 | 02:56 PM
bleedblue94's Avatar
it also matters if you torqued the im down in the proper sequence...
Old Mar 31, 2009 | 07:09 PM
slob20ef's Avatar
ok i did start the car and cover the TB Vacuum, and it did nothing. Im not even sure where to look for this vacuum, When everyone is saying clean the IACV im not even sure where it is. and the manifold is torqued in sequence to spec. Anything else guys? This hunting idle is super annoying, and it does it all the time, not just when its cold
Old Mar 31, 2009 | 07:13 PM
You clearly have a massive vacuum or intake air leak. Check for any disconnected vacuum hoses. Otherwise, you may need to retorque the throttle body and IM or replace the gaskets.
Old Mar 31, 2009 | 07:18 PM
Swansen's Avatar
there is your answer there, alternatively you can have a shop do a smoke test, it finds vacuum leaks, and only takes like 10 minutes.
Old Mar 31, 2009 | 07:23 PM
slob20ef's Avatar
i know that the vacuum to the throttle body is not hooked up, and there is a vacuum from the evap unit that sits on the side of the manifold, one goes to the Secondary IAB, and i know there is suppose to be another one that comes from it, I took out the black evap canister or whatever it is, that runs all the vacuum
Old Mar 31, 2009 | 07:25 PM
Have you blocked all those vacuum nozzles on the IM? If not, there's the problem.
Old Mar 31, 2009 | 07:28 PM
slob20ef's Avatar
no i have not, just wondering all what nozzles to block, and whats the easiest way to do it? Thanks alot guys
Old Apr 1, 2009 | 04:18 PM
slob20ef's Avatar
anyone?
Hondapreludeg
Honda Civic (2001 - 2005)
14
Feb 18, 2013 02:23 PM
SOHC_civic_si
16
Dec 29, 2010 02:25 PM
googoodc
Jan 25, 2009 03:26 PM
1990_integra_DA9
Oct 7, 2008 05:06 PM
ARACER25
Oct 13, 2002 10:41 AM
