Which throttle cable-- 99/00 civic hatch with b18c1 swap?
Old Mar 30, 2009 | 06:08 PM
Nino_eg6's Avatar
Default Which throttle cable-- 99/00 civic hatch with b18c1 swap?
I wanted to know what throttle cable to use with a b18c1 swapped into a 00 civic hatch. The single cam and gsr cables were to long. I wanted to know if a b16 throttle cable would work before going out to purchase one. Thanks in advance
Old Mar 30, 2009 | 06:36 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: Which throttle cable-- 99/00 civic hatch with b18c1 swap?
it should be the same length, pull the cable into the car a little and zip tie it to stay.
Old Mar 31, 2009 | 11:41 AM
Nino_eg6's Avatar
alright thanks
Old Mar 31, 2009 | 11:52 AM
Groovinator's Avatar
the type r one fits a lot better, but yes the b16 cable will work, just need some zip ties.
type r part # 17910-ST7-R01
Old Mar 31, 2009 | 12:47 PM
gill0607ek9's Avatar
no gsr should fit fine im using a gsr on my civic unless you have different manifold
Old Mar 31, 2009 | 01:28 PM
Nino_eg6's Avatar
nope its the stock gsr manifold
Old Mar 31, 2009 | 06:13 PM
Nino_eg6's Avatar
im thinking im going to try the b16 throttle cable because I've heard from 3 people thats what they are using. thanks for the help guys
Old Mar 31, 2009 | 08:43 PM
Ya Digg's Avatar
you gotta use the one matching the motor shouldnt be to long.
b18buck
Sep 2, 2009 07:24 AM
gsrboy18
Oct 11, 2005 11:52 AM
s2000june
12
Aug 15, 2005 02:35 AM
dynamo
Jul 4, 2005 07:41 PM
Cynical 1
Sep 19, 2002 09:46 AM
