A good way to keep shift boot up?
Heres what I used to do. Its a good fix if your shift **** doesnt line up right too. Its not a pain in the *** either, and you dont have to worry about messing with a bolt when you want to take the boot off.
Get a roll of electrical tape, take off the shift boot and all that, screw your shift **** on as far as you can (or if your **** doesnt line up, screw it down as low as you can, then back it out to where you want it). Next, take the electrical tape and right below where the shift **** ends, put a few layers of tape around the shifter. Pop off the ****, throw on the boot, and screw on the **** and it should be all flush. If it slides over the tape easy, add some more layers.
Pull the boot down, wrap some elctrical tape around your shifter (just enough so you can pull the boot back up over the tape but enough so its a tight squeeze and will hold the boot up)...done.
throw a zip tie around the inside then flip the boot....problem solved, its held up and you cant even tell that its fastened. imo that it looks better to show a little of the shifter if your running a nice dual bend or similar. i have my boot pushed down to keep it out of the way when shifting and plush i get to show off my s2 dual bend.
wrap electrical tape below the shift **** just past the threads, you dont need very much. when you pull the boot up it will be snug and fit perfect
Was trying to solve this today, been doing a lot of final cosmetic stuff on my DD/Project Civic. Today I was cleaning the center console trim and other various plastic things, and as I had my shift boot removed and cleaning it, I noticed the rubber ring on the top of the boot was cracked, so I flipped out the boot and zipped up the rubber ring. And then I realized I can do the same thing to the shift stick itself to hold the boot up. So I got one of my small metal hose clamps and secured it on the shift stick, moved up/down according to where I want the top of the boot to sit, and voila! The boot is nice and snug against the **** and my center console looks whole again.
done
Oct 10, 2002 06:24 AM
