Shift Boot attachment methods?
Old Aug 7, 2004 | 08:16 PM
daich's Avatar
Default Shift Boot attachment methods?
What are some methods of attaching the top portion of the shift boot to the **** (esp a machined billet ****!)?
I'm looking for a permanent and clean looking way for the shift boot to stay all the way at the top of the shaft, just below the ****.
any hints, tips, advice?
thanks!
daich
Old Aug 7, 2004 | 08:36 PM
itsJDMyo's Avatar
Default Re: Shift Boot attachment methods? (daich)
well, i have a skunk2 ****, and there is a bolt that is suppose to be underneath it that locks it in place...obviously a shiftboot will not stick up on the bolt, so i put duct tape around it, then keep on moving the shiftboot up, once i realize that i put enough duct tape on the bolt, then i just slide the boot up and it stays in place
Old Aug 7, 2004 | 09:47 PM
YEE*MagicEK20kombobomber's Avatar
* B A N N E D *
Default Re: Shift Boot attachment methods? (itsJDMyo)
sounds dumb, but i wrapped a thick rubber band on the shifter...tight enough hold position, but loose enough to be able to slide it back down. holds the shift boot up tight to my gsr **** and know one even knoes how
lookie, i even made a cut away diagram
Old Aug 7, 2004 | 10:04 PM
itsJDMyo's Avatar
Default Re: Shift Boot attachment methods? (Veritek)
dumb? it's exactly the same thing you did, except you use a rubber band
Old Aug 7, 2004 | 10:06 PM
* B A N N E D *
naw, im saying my idea sounds dumb, not urs. lol
Old Aug 7, 2004 | 10:11 PM
HeyMikeyyyy's Avatar
Default Re: (DV)
you mean something like this???
Itr **** and shift boot i just used th nut that came with it and put it over the boot.. works like a charm and my #s line up perfect....
Old Aug 7, 2004 | 10:12 PM
* B A N N E D *
Default Re: (DV)
the lockin nut is for the shift ****. same concept as locking perches. because if u just thread down a skunk 2, or itr/ctr ****, the shift pattern on top isnt always centered.
Old Aug 7, 2004 | 10:55 PM
Boltz's Avatar
Heres what I did.
-Put some weatherstrip (1/2") around the spot on the shifter youd like the boot to stick.
-Slide plastic console with boot over the shifter and below the weatherstrip.
-Pull the console up enough that you can see and work under it but not too far that the boot goes above the weatherstrip on the shifter.
-Take the outer circle (opening) on the shiftboot and pull it under about 3/4" (this is so you can actually keep it attached)
-Pull the top of the shift boot to the bottom of the weatherstrip.
-take a ziptie and tighten it over the opening of the shift boot on the top on the weatherstrip
-pull boot snug
Weatherstrip helps give the ziptie something to hold onto and looks clean in the small openings between the boot and shifter
Old Aug 7, 2004 | 10:56 PM
plusONE jboy's Avatar
yeah my shift boot is starting to sag, maybe i should try this rubberband method.
Hackura
Nov 29, 2014 10:45 PM
b18c inside
Mar 9, 2008 03:53 PM
pfcle
Honda Civic (2006 - 2015)
May 17, 2007 08:55 PM
andrewasf77
Nov 10, 2002 11:50 AM
done
Oct 10, 2002 06:24 AM
