when is a fuel pump needed?
is there a specific hp range where i will need a fuel pump to increase/maintain hp on a turboed engine? 300-350hp is my goal
b18c1 81.5 bore
rc 750 injectors (i know its a bit overkill, got a great price on them though)
skunk2 im
edelbrock performerx tb
skunk2 cam gears
9:1 compression
greddy turbo kit (i know its not the best turbo kit out there. planning on replacing the elbo+DP (the main problem areas with that kit) and maybe porting the flapper door since thats a problem area also. need something that if a cop takes a peak under my hood everything will look legal though)
going to tune on ectune or neptune, havent decided which yet
b18c1 81.5 bore
skunk2 im
skunk2 cam gears
9:1 compression
This is somewhat beating a dead horse....but buy a pump is a very minute item to buy as insurance of your set-up. with you boosting it at all thats something you want to replace/upgrade period, No Questions ask...You dont know the history of the car and pump and that's something that can fail easy under it's new form of work(boost)....
Thats like buying a motor out of the junk yard rebuild the internals but use the oil/water pump that came on it.....Not going to happen...
Replace or FAIL!!!
Replace or FAIL!!!
Just make sure the pick up sits low enough in the tank compared to the OE.
I fitted a 255 over the weekend, I now have to make sure the tank is no lower than 1/4 full.
I was making 350 (UK fly HP in 4th gear) on 750’s GT30r B18 with no problems for more than a year and 330 on a B16 all with OE Honda pump.
