when is a fuel pump needed?
Old Mar 29, 2009 | 04:16 PM
xander1100's Avatar
Default when is a fuel pump needed?
is there a specific hp range where i will need a fuel pump to increase/maintain hp on a turboed engine? 300-350hp is my goal
b18c1 81.5 bore
rc 750 injectors (i know its a bit overkill, got a great price on them though)
skunk2 im
edelbrock performerx tb
skunk2 cam gears
9:1 compression
greddy turbo kit (i know its not the best turbo kit out there. planning on replacing the elbo+DP (the main problem areas with that kit) and maybe porting the flapper door since thats a problem area also. need something that if a cop takes a peak under my hood everything will look legal though)
going to tune on ectune or neptune, havent decided which yet
Old Mar 29, 2009 | 04:20 PM
fmfkid250's Avatar
Default Re: when is a fuel pump needed?
I ran out on a D series yesterday at 200whp
Old Mar 29, 2009 | 05:42 PM
xander1100's Avatar
for d series 200whp was max without a pump? ouch
Old Mar 29, 2009 | 06:59 PM
1qwkinline4's Avatar
This is somewhat beating a dead horse....but buy a pump is a very minute item to buy as insurance of your set-up. with you boosting it at all thats something you want to replace/upgrade period, No Questions ask...You dont know the history of the car and pump and that's something that can fail easy under it's new form of work(boost)....
Thats like buying a motor out of the junk yard rebuild the internals but use the oil/water pump that came on it.....Not going to happen...
Replace or FAIL!!!
Old Mar 29, 2009 | 07:27 PM
welfarepc's Avatar
you need a new fuel pump when your fuel pressure falls off. end thread.
Old Mar 29, 2009 | 08:21 PM
srmofo's Avatar
walbros are less than 100$....just buy it, its plenty for your goal
Old Mar 29, 2009 | 09:22 PM
xander1100's Avatar
thx for input
Old Mar 30, 2009 | 02:30 AM
EddieCRX's Avatar
Just make sure the pick up sits low enough in the tank compared to the OE.
I fitted a 255 over the weekend, I now have to make sure the tank is no lower than 1/4 full.
I was making 350 (UK fly HP in 4th gear) on 750’s GT30r B18 with no problems for more than a year and 330 on a B16 all with OE Honda pump.
noluckracing
Apr 28, 2009 11:11 PM
rip94delsol
Nov 11, 2008 04:18 AM
envee
Feb 24, 2007 06:08 PM
muskrat hatch
May 20, 2004 06:27 PM
tolowhb
May 11, 2003 08:46 PM
