Problem With My 92 Si Hatchback
car stalls and doesnt idle, codes thrown were for the tdc censor and lyc sensor, i already replaced the o2 sensor. and that code isnt thrown any more. distributor is pretty new. not even 7 months old.
You haven't received any responses because your original post is way too long and contains a lot of irrelevant information. You need to summarize.
Is the following summary correct:
You own a 92 Civic Si with D16Z6 engine.
The engine starts but stalls, possibly due to a low idle.
The CEL is ON, and the CEL codes are for the primary O2 sensor, the TDC sensor in the distributor, and for lyc sensor(?). Not sure what the last one is. What were each of the specific CEL codes?
Right now, my guess is that your problem is primarily caused by the TDC sensor problem. This could be a bad sensor or wiring for the sensor. If the sensor is bad, you need to replace the distributor subassembly.
