Stripped crank pulley bolt
Old Mar 29, 2009 | 03:13 PM
sde780's Avatar
Default Stripped crank pulley bolt
Is there any options left for me if I stripped the crank pulley bolt? I just got my cheater pipe and crank pulley removal tool, first time I tried it it stripped
Old Mar 29, 2009 | 07:11 PM
Crashedcivic's Avatar
Default Re: Stripped crank pulley bolt
Ouch.. If there are any threads left in the hole a machine shop may be able to re-thread it. If not.. then they can bore it out a little and put a steel sleeve to match the bolt. They will need the bolt that goes in it to match up the steel sleeve. I did this with the tensioner pulley bolt, cost about $50. Good luck!
Old Mar 29, 2009 | 07:13 PM
Ls_dx's Avatar
Did you strip the bolt? Meaning you rounded it off.. ?
Old Mar 29, 2009 | 07:19 PM
FlatBrokeHatch's Avatar
That's what it sounds like. If the correct size/quality socket was used...there should be no chance for it to strip.
Old Mar 29, 2009 | 07:31 PM
TravisCadello's Avatar
holly ****. Buy a new crankshaft or Block lol. i did this and noone could fix mine so i welded my pulley lol. it worked for 4 months and up to aweek ago it fell off so im changing my block out cuz of that **** good luck.
Old Oct 9, 2010 | 06:50 PM
natethegreat54's Avatar
the thread is stipped on my crankshaft does any know the thread count so i can use a tap or dye so i can re-thread it
the bolt itself is fine just the thread where the pulley bolt goes it stripped it wont torque at all
Old Sep 3, 2013 | 07:34 AM
Markel Wall's Avatar
i dont knw if i stripped my bolt bt whn i tighten it i tightens a min den it just get loose wht should i do now
Old Sep 3, 2013 | 10:43 AM
sde780's Avatar
Your threads are stripped, you can heli-coil it or get a new crank
barrera
Oct 11, 2010 07:17 AM
Midori Green
Jun 3, 2008 07:00 PM
puffsef
Oct 19, 2005 09:50 AM
NatedoggAZ
Mar 18, 2004 08:56 AM
legendboy
Nov 22, 2002 10:42 AM
