Zc id
Old Mar 29, 2009 | 01:45 PM
CarGuy2010's Avatar
Default Zc id
Hi everybody, I'm new to this site. But I need some help.
I recently bought a 89 CRX si, and the guy I bought it from said that it had different engine and tranny swapped into it. He said the engine is a D16ZC, but I don’t know if that even exists. This is all the stuff it says on the front of the engine (L3-1441964 ZC 2407658).
My problem is, when I go to buy parts for the engine, I have no clue what to buy them for. Can someone please help me out? Thanks in advance!!!
Old Mar 29, 2009 | 01:48 PM
Ls_dx's Avatar
Default Re: Please Help
sohc or dohc?
Old Mar 29, 2009 | 01:49 PM
CarGuy2010's Avatar
Oh, sorry. Its a DOHC
Old Mar 29, 2009 | 02:12 PM
93formula's Avatar
most bottom end parts are d16a6, www.thezcr.com
Old Mar 29, 2009 | 02:23 PM
CarGuy2010's Avatar
Ok, awesome. I put up some pix of the engine in my garage.
Old Mar 29, 2009 | 02:45 PM
CarGuy2010's Avatar
Are you sure its a D16a6, cause those look like ( http://memimage.cardomain.com/ride_i...0002_large.jpg ) and my engine doesn’t look like that at all? Look in my garage at the CRX and you can see what my engine looks like.
Old Mar 29, 2009 | 03:45 PM
SC_HOBD_1816's Avatar
Use parts from 88-89 integra. The ZC DOHC is the jdm motor from 88-89 USDM integra motor. Some parts from the 88-91 prelude are compatible gotta do some research.
Old Mar 29, 2009 | 03:48 PM
Ignition/ timing parts
OBD1 distributor
TD43U
OBDO Distributor
TD03U 88-89 Integra .
_________
OBDO Distributor Cap
30102-PM7-305 88-91 CRX Si/88-89 Integra OEM .
. JP936 . WELLS .
. 44-9620 . VALUCRAFT .
. JP936G . GOLD .
. 8290 . MSD w/Coil Bypass .
_________
Distributor Cap gasket
OEM # 30132-PM5-A02
Rotor Button
88-91 Civic/CRX // 88-89 Integra
Brand—–Part#
OEM - 30103-PM5-A05
WELLS - JP923
VALUCRAFT - 33-8220
Spark plug wires
88-89 Acura Integra
Brand—–Part#
OEM -
MSD - 32339
MAGNECOR - 45125
NGK - NGK-HE48
NOLOGY - 011014011
**If not going for High performance wires USE OEM all others are inferior except for performance wires.**
Spark Plugs
Dont waste your money on platinums or iridiums
NGK is standard from Honda. If your Boosting the motor choose your type carefully as a standard plug is not for you, you will need a colder plug.
88-91 Civic/CRX si 1.6L // 88-89 Integra
Brand—–Part#
NGK V-POWER - BCPR6E-11
Spark plug tube seals
86-89 Integra
OEM # 12342-PT2-000
Distributor O- ring and CPS O-ring
88-89 Integra
OEM # 30110-PA1-732
Water Pump
88-91 CRX/Civic
Brand—–Part#
___________
OEM - 19200-P01-003 or 19200-P01-004
Water Pump Gasket
*If your gasket is leaking You might as well get a new pump and it will come with the gasket*
___________
Oil Pump
88-91 Civic/CRX
OEM # 15100-P06-A01
Timing Belt
1988 Prelude 2.0 Si.
Brand—–Part#
OEM - 14400-pk2-004
NOTE:I have heard people get part #14400-pk2-003
they should be the same
Timing belt tensioner
OEM part # 14510-PM7-004
Gaskets and head parts
Cylinder Head Gasket
1988 & 89 Integra
Brand—–Part#
OEM - 12251-PM7-003
FELPRO - 9451PT-1
HKS BEAD - 2302-RH001 (0.7mm Thick/76mm Bore/9.9 CR)
HKS GROMMET - 2301-RH010 (0.6mm Thick/76mm Bore/10 CR)
_____________
Head Studs ARP
tunertoys.com sells the zc studs get them from their site
http://tunertoys.zoovy.com/product/2...C_engines.html
___________
Intake Manifold Gasket
1988 & ‘89 Integra
Brand—–Part#
OEM - 17105-PG6-S00
FELPRO - MS93362
Exhaust Manifold Gasket
1988 & ‘89 Integra
Brand—–Part#
OEM - 18110-PG6-003
FELPRO - MS93363
Header
88 - 91 CRX/Civic Headers will fit. The ports are off just a tad but the bolt pattern is money. Nothing a little grinding can’t fix.
Throttle Body
88 - 91 Civic/CRX Si 1.6L
Throttle Body Gasket
88-91 Civic/CRX Si 1.6L only
Brand—–Part#
OEM - 16176-PM6-S00 or 16176-PM6-000
Radiator Hoses
*Upper: 88-89 Integra
*Lower: 88-91 Civic/CRX
Brand—–Part#
OEM Lower Hose - 19502-PM3-000
OEM Upper Hose -
Valve cover Gasket
86-89 Integra
Brand—–Part#
OEM - 12341-PM7-000
Valve cover stud Grommets
90-93 Integra 1.8L
**OEM part # 90442-PR3-000
Thermostat
88-91 CRX/Civic
Brand—–Part#
Stant OEM TEMP - 45878
Prestone OEM TEMP - 392180
Fuel Injectors
88 - 91 CRX/Civic Si / 86-89 Integra
Fuel Injector
Brand—–Part#
OEM - 06164-PK2-010
silinoids and electronic parts
IACV (Intake Air controll valve)
88-91 Civic/CRX
oem # 36455-PT3-A01
CPS (Cylinder Position Sensor)
1988 & 89 Integra 1.6l
Brand—–Part#
OEM - 37841-PG7-006
Alternator
88-91 CRX/Civic
Alternator:
Get a NAPA if you must use other than OEM, but try to stay OEM here if you can. Advance and Autozone and most other parts stores Have VERY LOW quality replacements…**Why do you think they have to offer a lifetime warranty??..( a little something to make you think)
Brand—–Part#
OEM - 31100-PM8-A03RM or 31100-PM8-A03RMD
Bottom End Components
Rear Main Seal
1988 & 89 Integra
Brand—–Part#
OEM - 91214-PH1-013
Oil Pan
88-89 Integra -the Integra pan will only work if you also use the Integra oil pump pickup
88-91 CRX/Civic -the 88-91 CRX/Civic Si D16A6 oil pan works without changing the pickup
the D16A1 pan is slightly deeper than the D16A6 and requires 1/2 quart more oil
Brand—–Part#
OEM #
Oil Pan Gasket
Brand—–Part#
OEM - 11251-P01-004
FELPRO - OS30542R
ROL - OS5725
_________
Oil Filter
The S2000 OEM Filters will work also and are made by a reputable company in Japan that makes high performance oil filters, but you will pay more for them.
MY Suggestion…Get OEM Its only a couple bucks so why buy others when you can have a OEM filter for mostly the same price.
Brand—–Part#
OEM -
STP - S2808
FRAM - PH6811
K&N - HP-1004
MOBIL - M1-104
______________
Connecting rods
But any D-series 1.6L rods will work for upgrading.
______________
Pistons
88-89 Integra OEM
the std bore on a zc is 75mm so anything with that bore would work. a6,z6.ect. will work as long as it's a 75mm. but it depends on the compression you want to run.
There are many companies that offer ZC specific Pistons now, so Aftermarket is there.
______________
Main & Rod bearings and thrust washer bearings
______________
Piston Rings
88-91 Civic/CRX // 86-89 Integra
______________
Engine and tranmission Mounts
1988 - 1991 CRX/Civic (All trim levels)
Brand—–Part#
OEM - 50810-SH3-040 (Rear, Firewall Mount)
OEM - 50805-SH3-040 (Transmission Mount)
OEM - 50821-SH3-040 (Side Mount, By Timing Belt)
OEM - 50840-SH3-000 (Front Mount)
__________________
Old Mar 30, 2009 | 05:30 AM
jlicrx's Avatar
the DOHC ZC with engine serial number beginning with the number '2' came in the 88-91 JDM Civic Si model and the 88-91 JDM CRX Si model, not in the JDM Integra
Old Mar 30, 2009 | 05:36 AM
CarGuy2010's Avatar
Default Re: Zc id
Wow!
Thanks very much for the information guys.
You rock SC_HOBD_1816
Old Mar 30, 2009 | 04:06 PM
Default Re: Zc id
no problem. just did a simple research.
ShreqBoi
Aug 6, 2010 02:34 PM
sandiegosmoka
Classic Hondas
May 12, 2009 02:26 PM
MugenFlaredCRX
Sep 9, 2004 04:20 AM
