Zc id
Hi everybody, I'm new to this site. But I need some help.
I recently bought a 89 CRX si, and the guy I bought it from said that it had different engine and tranny swapped into it. He said the engine is a D16ZC, but I don’t know if that even exists. This is all the stuff it says on the front of the engine (L3-1441964 ZC 2407658). My problem is, when I go to buy parts for the engine, I have no clue what to buy them for. Can someone please help me out? Thanks in advance!!! |
Re: Please Help
sohc or dohc?
Re: Please Help
Oh, sorry. Its a DOHC
Re: Please Help
most bottom end parts are d16a6, www.thezcr.com
Re: Please Help
Ok, awesome. I put up some pix of the engine in my garage.
Re: Please Help
Are you sure its a D16a6, cause those look like ( http://memimage.cardomain.com/ride_i...0002_large.jpg ) and my engine doesn’t look like that at all? Look in my garage at the CRX and you can see what my engine looks like.
Re: Please Help
Use parts from 88-89 integra. The ZC DOHC is the jdm motor from 88-89 USDM integra motor. Some parts from the 88-91 prelude are compatible gotta do some research.
Re: Please Help
Ignition/ timing parts OBD1 distributor TD43U OBDO Distributor TD03U 88-89 Integra . _________ OBDO Distributor Cap 30102-PM7-305 88-91 CRX Si/88-89 Integra OEM . . JP936 . WELLS . . 44-9620 . VALUCRAFT . . JP936G . GOLD . . 8290 . MSD w/Coil Bypass . _________ Distributor Cap gasket OEM # 30132-PM5-A02 Rotor Button 88-91 Civic/CRX // 88-89 Integra Brand—–Part# ————— OEM - 30103-PM5-A05 WELLS - JP923 VALUCRAFT - 33-8220 Spark plug wires 88-89 Acura Integra Brand—–Part# ————— OEM - MSD - 32339 MAGNECOR - 45125 NGK - NGK-HE48 NOLOGY - 011014011 **If not going for High performance wires USE OEM all others are inferior except for performance wires.** Spark Plugs Dont waste your money on platinums or iridiums NGK is standard from Honda. If your Boosting the motor choose your type carefully as a standard plug is not for you, you will need a colder plug. 88-91 Civic/CRX si 1.6L // 88-89 Integra Brand—–Part# ————— NGK V-POWER - BCPR6E-11 Spark plug tube seals 86-89 Integra OEM # 12342-PT2-000 Distributor O- ring and CPS O-ring 88-89 Integra OEM # 30110-PA1-732 Water Pump 88-91 CRX/Civic Brand—–Part# ___________ OEM - 19200-P01-003 or 19200-P01-004 Water Pump Gasket *If your gasket is leaking You might as well get a new pump and it will come with the gasket* ___________ Oil Pump 88-91 Civic/CRX OEM # 15100-P06-A01 Timing Belt 1988 Prelude 2.0 Si. Brand—–Part# ————— OEM - 14400-pk2-004 NOTE:I have heard people get part #14400-pk2-003 they should be the same Timing belt tensioner OEM part # 14510-PM7-004 Gaskets and head parts Cylinder Head Gasket 1988 & 89 Integra Brand—–Part# ————— OEM - 12251-PM7-003 FELPRO - 9451PT-1 HKS BEAD - 2302-RH001 (0.7mm Thick/76mm Bore/9.9 CR) HKS GROMMET - 2301-RH010 (0.6mm Thick/76mm Bore/10 CR) _____________ Head Studs ARP tunertoys.com sells the zc studs get them from their site http://tunertoys.zoovy.com/product/2...C_engines.html ___________ Intake Manifold Gasket 1988 & ‘89 Integra Brand—–Part# ————— OEM - 17105-PG6-S00 FELPRO - MS93362 Exhaust Manifold Gasket 1988 & ‘89 Integra Brand—–Part# ————— OEM - 18110-PG6-003 FELPRO - MS93363 Header 88 - 91 CRX/Civic Headers will fit. The ports are off just a tad but the bolt pattern is money. Nothing a little grinding can’t fix. Throttle Body 88 - 91 Civic/CRX Si 1.6L Throttle Body Gasket 88-91 Civic/CRX Si 1.6L only Brand—–Part# ————— OEM - 16176-PM6-S00 or 16176-PM6-000 Radiator Hoses *Upper: 88-89 Integra *Lower: 88-91 Civic/CRX Brand—–Part# ————— OEM Lower Hose - 19502-PM3-000 OEM Upper Hose - Valve cover Gasket 86-89 Integra Brand—–Part# ————— OEM - 12341-PM7-000 Valve cover stud Grommets 90-93 Integra 1.8L **OEM part # 90442-PR3-000 Thermostat 88-91 CRX/Civic Brand—–Part# ————— Stant OEM TEMP - 45878 Prestone OEM TEMP - 392180 Fuel Injectors 88 - 91 CRX/Civic Si / 86-89 Integra Fuel Injector Brand—–Part# ————— OEM - 06164-PK2-010 silinoids and electronic parts IACV (Intake Air controll valve) 88-91 Civic/CRX oem # 36455-PT3-A01 CPS (Cylinder Position Sensor) 1988 & 89 Integra 1.6l Brand—–Part# ————— OEM - 37841-PG7-006 Alternator 88-91 CRX/Civic Alternator: Get a NAPA if you must use other than OEM, but try to stay OEM here if you can. Advance and Autozone and most other parts stores Have VERY LOW quality replacements…**Why do you think they have to offer a lifetime warranty??..( a little something to make you think) Brand—–Part# ————— OEM - 31100-PM8-A03RM or 31100-PM8-A03RMD Bottom End Components Rear Main Seal 1988 & 89 Integra Brand—–Part# ————— OEM - 91214-PH1-013 Oil Pan 88-89 Integra -the Integra pan will only work if you also use the Integra oil pump pickup 88-91 CRX/Civic -the 88-91 CRX/Civic Si D16A6 oil pan works without changing the pickup the D16A1 pan is slightly deeper than the D16A6 and requires 1/2 quart more oil http://i5.photobucket.com/albums/y18.../car/pans1.jpg Brand—–Part# ————— OEM # Oil Pan Gasket Brand—–Part# ————— OEM - 11251-P01-004 FELPRO - OS30542R ROL - OS5725 _________ Oil Filter 88-91 Civic/CRX // 88-89 Integra The S2000 OEM Filters will work also and are made by a reputable company in Japan that makes high performance oil filters, but you will pay more for them. MY Suggestion…Get OEM Its only a couple bucks so why buy others when you can have a OEM filter for mostly the same price. Brand—–Part# ————— OEM - STP - S2808 FRAM - PH6811 K&N - HP-1004 MOBIL - M1-104 ______________ Connecting rods 88-91 Civic/CRX Si 1.6L But any D-series 1.6L rods will work for upgrading. ______________ Pistons 88-89 Integra OEM the std bore on a zc is 75mm so anything with that bore would work. a6,z6.ect. will work as long as it's a 75mm. but it depends on the compression you want to run. There are many companies that offer ZC specific Pistons now, so Aftermarket is there. ______________ Main & Rod bearings and thrust washer bearings 88-91 Civic/CRX si 1.6L ______________ Piston Rings 88-91 Civic/CRX // 86-89 Integra ______________ Engine and tranmission Mounts 1988 - 1991 CRX/Civic (All trim levels) Brand—–Part# ————— OEM - 50810-SH3-040 (Rear, Firewall Mount) OEM - 50805-SH3-040 (Transmission Mount) OEM - 50821-SH3-040 (Side Mount, By Timing Belt) OEM - 50840-SH3-000 (Front Mount) __________________ |
Re: Please Help
Originally Posted by SC_HOBD_1816
(Post 37959403)
Re: Zc id
Wow! :o
Thanks very much for the information guys. You rock SC_HOBD_1816 |
Re: Zc id
no problem. just did a simple research.
