Honda S2000 Honda S2000
Widebands? Where do you run them?
Old Mar 28, 2009 | 08:26 PM
ExVtec's Avatar
Default Widebands? Where do you run them?
Installing my aem wideband, I'm curious where you guys run them. From inside the cab to underneath the car?
Old Mar 28, 2009 | 08:29 PM
dagle's Avatar
Default Re: Widebands? Where do you run them?
transmission tunnel looks like there would be space, either that or through the footwell area> behind the dash > to your gauges would work too
but atm no gauges at all, my interior looks stock just the way i like it
Old Mar 28, 2009 | 08:42 PM
HondaKyle's Avatar
the same fire wall I ran my boost and oil PSI gauge threw... I dont know how to explain it...
Old Mar 28, 2009 | 08:54 PM
boostedh22a's Avatar
There are grommets on both sides of the engine bay on the firewall where you can pass wires through. If you are turbocharged, I would recommend installing the wideband sensor a couple of feet down stream from the turbo.
Old Mar 28, 2009 | 08:59 PM
dagle's Avatar
i thought you wanted it like less than 12" down from where the downpipe starts for the wideband and off of the hottest runner on the mani for the EGT (don't remember which cyl for hondas)
Old Mar 28, 2009 | 09:13 PM
HondaKyle's Avatar
the o2 is 6 inchs down from the factory o2 before the cat.
Old Mar 29, 2009 | 09:28 AM
ExVtec's Avatar
Ok, I was curious how to get from inside the cab to underneath. Figured their was a grommet.
Old Mar 29, 2009 | 09:35 AM
Straight from my AEM manual
"Mount the O2 sensor in the exhaust system at least 18" downstream from the exhaust port. If you anticipate high EGT's, run a turbocharger, run at high RPM for extended periods of time or plan on running leaded race fuel then you MUST mount the sensor at least 36" or more downstream of the exhaust port as all of these can cause the sensor to overheat"
Old Mar 29, 2009 | 09:41 AM
dagle's Avatar
haha i'm not sure then, on my prelude motor that i got rid of, the new owner tapped the wideband very close to the manifold, and the EGT on the manifold
Old Mar 29, 2009 | 11:56 AM
That doesn't mean he did it right....haha.
EGT's should be very close to the exhaust ports to be accurate. Widebands are another story.
Old Mar 29, 2009 | 12:09 PM
S2KFTW's Avatar
I ran the wiring across to the passenger side and out the grommet behind the battery. that way the wiring doesn't have to cross the engine bay to get to the sensor. I still have the stock header so I used the primary O2's location. basically you want to measure from a point that has input from all 4 cylinders.
on a turbo setup I would just put the O2 on the downpipe. there's a limit to the temperature that an O2 can handle so you don't want to put it right off the turbo where the temps are the highest. maybe a little closer to the firewall where the temps are down a little.
Old Mar 29, 2009 | 03:33 PM
ExVtec's Avatar
I ended up running it out the grommet on the drivers side beside the clutch.
Worked out fine.
I am going to put it near the stock location, which is underneath the passenger.
Old Mar 29, 2009 | 05:37 PM
S2KFTW's Avatar
that's should be just fine
Old Mar 29, 2009 | 06:07 PM
rice4life's Avatar
i run my wire through the grommet underneath the clutch master cylinder, there one on the battery side also.
Old Mar 30, 2009 | 06:04 AM
ExVtec's Avatar
Thats where I ran mine too ^^
turboH22Aakkord
Sep 6, 2005 02:57 PM
BDogggUT34
16
Jan 27, 2005 05:10 PM
819turbo
Apr 19, 2004 12:38 PM
Pengo
Jun 30, 2002 04:15 PM
Duck Sauce
Dec 24, 2001 01:58 AM
