gauges!!!!
Old Apr 19, 2004 | 07:02 AM
819turbo's Avatar
Default gauges!!!!
i've searched alot, and i have realize that alot of people do not like the a/f gauge why? i thought that if i only and boost and a/f gauges i would be good. my turbo setup ( b20b @ 8 psi) is almost finish and i need to deside with gauges to buy. The reason i thought a/f guage was good is cuz, i' m ganna do some street tuning and with the b20b i CANNOT affort to run just a little lean. please post your choices of gauges and why the a/f gauge is not good ( for those who do not like it).
Old Apr 19, 2004 | 07:06 AM
DaX's Avatar
DaX
Loved
Community Favorite
AF gauge is junk...it does not give accurate readings...especially if you're going to be tuning. What EMS are you using? Most people will agree the best gauges to have are Boost, Oil Pressure, and EGT.
Old Apr 19, 2004 | 07:14 AM
819turbo's Avatar
ems??? dot no waht that means but i will be running 8 psi with 440cc injector, smc plus, 255 fuel pump and a reprogram ecu.
if i get a egt instead of a a/f , then how can i now if i will be running lean or not? how do you street tune with egt?
Old Apr 19, 2004 | 07:20 AM
B18Flip's Avatar
Default Re: (819turbo)
you can't street tune with a narrowband a/f guage or an EGT...you'll need to get a wideband like a PLX, aem, fjo, techedge etc.....
Old Apr 19, 2004 | 07:28 AM
DaX's Avatar
DaX
Loved
Community Favorite
EMS = engine management system. Who / what kind of reprogrammed ECU do you have?
For tuning purposes you'll need a wideband lambda meter [like b18flip said], but as for gauges that are the best to have for driving, EGT, Oil pressure, and boost.
Old Apr 19, 2004 | 07:33 AM
B18Flip's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">EMS = engine management system. Who / what kind of reprogrammed ECU do you have?
For tuning purposes you'll need a wideband lambda meter [like b18flip said], but as for gauges that are the best to have for driving, EGT, Oil pressure, and boost.</TD></TR></TABLE>
Agreed, all of them are a must. I recently learned the importance of an oil pressure guage when my car was plagued with oil problems .....think he's running Zip's SMC plus. That's the one with 500 rpm increments right?
Old Apr 19, 2004 | 07:56 AM
quikB18B's Avatar
Default Re: (B18Flip)
Yeah Air fuel gauges are nothing more than a light show.
Old Apr 19, 2004 | 08:36 AM
SOHC_MShue's Avatar
Default Re: gauges!!!! (819turbo)
yea the a/f gauge isn't giving you a precise number to tune by. You'll need a wideband.
Old Apr 19, 2004 | 09:47 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">Yeah Air fuel gauges are nothing more than a light show.
Right. If you want a light show, go to a rave.
Old Apr 19, 2004 | 12:04 PM
819turbo's Avatar
Default Re: (DaX)
lol.....funny. ok then should i get a wideband a/f ( how much do these come by? ) or a egt. but it seems that the most popular gauges setup is oil pressure + boost + egt. so want is the egt gauge ganna tell me? ( i no that it is exhaust gas temp., but i've never seen one. is it ganna tell me that i'm lean or not or......? please keep giving me feedback, you guys are really helping me. thx.
Old Apr 19, 2004 | 12:12 PM
DaX's Avatar
DaX
Loved
Community Favorite
EGT will tell you exhaust gas temperatures. If these are too high, either something is wrong or you're in it too hard and need to back off.
As far as WB devices, I'm fond of the PLX M300 WideBand controller with display. It has a digital dash mountable display, and can emulate a narrowband signal for the ECU while giving a wideband output to the display. The M300 also uses the less expensive Bosch wideband sensor [as compared to the hideously expensive NGK sensor].
Old Apr 19, 2004 | 12:20 PM
fab-forum.com's Avatar
Default Re: (DaX)
AEM has a wideband gauge setup, runs roughly around $350
Old Apr 19, 2004 | 12:28 PM
819turbo's Avatar
is it possible tu run a autometer a/f gauge an get a wideband o2 sensor that the automter can read?
Old Apr 19, 2004 | 12:38 PM
B18Flip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 819turbo &raquo;</TD></TR><TR><TD CLASS="quote">is it possible tu run a autometer a/f gauge an get a wideband o2 sensor that the automter can read?</TD></TR></TABLE>
kinda...but you still can't steet tune on just looking at the lights. Check these out http://www.streetrays.com/cata...3eb80
totsie7944
Oct 6, 2007 07:56 PM
jdm.ej
May 20, 2004 05:16 AM
ninja8oi
Dec 14, 2003 05:10 PM
Goldfingiz
Jul 21, 2003 04:26 AM
ceemarun
May 7, 2002 07:11 PM
