CEL stays on & isnt throwing a code
Old Mar 28, 2009 | 06:21 PM
Thizzed Out's Avatar
Default CEL stays on & isnt throwing a code
Well I had my CEL for #22 which is Vtec pressure so I went ahead and changed the VALVE TIMING OILPRESSURE SWITCH. I unplugged the batt. before I did this like i always do when doing anything to the motor.
Well after I changed it and turned on the car the CEL came on, so I was like okay fine I'll read the code again. But the thing is it isn't throwing a code, It just stays on.
Whats up? Can I get some info on this problem.
Thanks!
Old Mar 28, 2009 | 06:34 PM
Former User's Avatar
Default Re: CEL stays on & isnt throwing a code
Did you leave the jumper wire in the service connector? Otherwise, check for a short in the service connector circuit. Start by inspecting the connector and the BACKUP fuse slot for damage. Another possibility is a bad ECU, though check the circuit first.
Old Mar 28, 2009 | 06:42 PM
Okay thanks now i got it, its throwing the code now.
its throwing #22 and #6. I thought changing the oil pressure switch would fix #22, and well #6 I don't know why that one is throwing now.
Old Mar 28, 2009 | 06:47 PM
Code 6 is for the coolant temperature sensor circuit.
Old Mar 28, 2009 | 06:51 PM
so I just buy a sensor for #6, but how can i fix #22? what do i need to do now i thought buying the oil pressure switch would fix the problem but i guess not.
Old Mar 28, 2009 | 06:55 PM
What year/emgine Civic?
Keep in mind that the coolant sensor may be fine and instead the wiring is bad. You should do some troubleshooting before purchasing the sensor, which is the 2-wire one beneath the distributor.
Old Mar 28, 2009 | 07:01 PM
1995 gsr motor, Yeah i pulled the connector for the coolant sensor to connector to reach the 1-wire temp wire becuase it wasnt connected correctly.
I connected it back on, but I guess its still throwing the code.
I'll check the wiring again, any idea on code 22?
Old Mar 28, 2009 | 07:07 PM
Have you measured the oil pressure, checked the switch wiring, and the VTEC solenoid valve?
Old Mar 29, 2009 | 05:09 AM
ill do that tomorrow morning, how would i know if the Vtec solenoid is good?
LoseRPunKx182
Aug 4, 2005 01:50 AM
ventura77
Jan 17, 2005 02:02 PM
integracivic94
Aug 22, 2004 08:42 AM
DBallz
Aug 29, 2003 05:56 PM
