Oil Coller with or without Thermostat
Old Mar 28, 2009 | 06:52 AM
ITR 05082's Avatar
Default Oil Coller with or without Thermostat
Oil Cooler with or without Thermostat? Is not it necessary or?
Your view?
Old Aug 4, 2009 | 01:10 AM
JORDS's Avatar
Default Re: Oil Coller with or without Thermostat
Im doing an oil cooler install atm, not sure if the thermostat is necessary, extended warm up will be required without the stat on cool days i guess.
where would you find an oil thermostat? any one gotta link.
Old Aug 4, 2009 | 07:14 AM
Tyrant_007's Avatar
Here's the one I'm probably going to get.
http://www.racerpartswholesale.com/c...Sandwich_Plate
Definitely nessesary if you live where it gets cold.
Old Aug 4, 2009 | 07:19 AM
92TypeR's Avatar
FSAE
If you drive in temperatures below 45*F I highly recommend a thermostat in your feed to your oil cooler. I ran a Mocal unit for a while and worked great, no issues. It was a part of the spin-on adapter on the block. They offer a T-stat and regular model.
The Mocal T-stat is ~10% open when it is "closed", so you still get circulation through the oil system. It would take me about 7-9 minutes of 'relaxed' driving to reach 180*F on the oil.
http://www.racerpartswholesale.com/p...Sandwich_Plate
Old Aug 8, 2009 | 06:21 PM
IN VTEC's Avatar
I swapped from a Mocal thermostat'd unit to a Canton without the thermostat. I ported it and partially block the oil cooler in the winter.
Old Aug 10, 2009 | 05:36 AM
sackdz's Avatar
https://honda-tech.com/forums/road-racing-autocross-time-attack-19/oil-cooler-thermostate-no-2622146/
realis9
May 23, 2006 08:55 PM
95gsrturbo
Apr 10, 2004 11:42 PM
Dan GSR
15
Feb 4, 2004 02:11 PM
90crxzc
Dec 6, 2003 01:36 PM
austrian type-R
Mar 16, 2003 04:07 AM
