Tranny Questions
Old Aug 13, 2002 | 07:08 PM
dinglenuts22's Avatar
Default Tranny Questions
i have a b16a1 and swapped my tranny from a 91 integ ls and my problem is that my speedometer is not working and my engine light turned on( code 17). My Vtec isn't working either cause i can't hear it at 5300rpm but no engine codes. is it becuase of the tranny or the code17 (Vehicle Speed Sensor) that i forget to put it on. pls help i appreciate it. than ks.
Old Aug 13, 2002 | 07:23 PM
Redline130's Avatar
Default Re: Tranny Questions (dinglenuts22)
Your speedo won't work unless you have the VSS hooked up. What ecu are you using to run the motor?
Old Aug 13, 2002 | 07:26 PM
EP3_05's Avatar
It is because you don't have the VSS hooked up. Vtec runs off of the speed sensor in addition to a couple of other sensors. I have the same problem. I left the VSS unplugged because I need to get the clip to hold the cable into the transmission. I don't have Vtec, I throw a code 17, and my rev limiter cuts in really early. So plug in the VSS and you should be fine.
Old Aug 14, 2002 | 03:04 PM
Default Re: Tranny Questions (91civic)
thank you!
1PT-SICK
Apr 22, 2006 02:15 PM
E36 Guy
Dec 11, 2003 03:15 PM
Import RP
Sep 24, 2003 11:21 PM
miataguy
Jul 17, 2003 02:25 PM
Mentat Ghola
Jan 13, 2003 10:38 PM
