Skunk2 pro vs. tuner camber kit
Yes the pro just has the newer ball joint. The pro plus has the new ball joint plus polyurethane bushings... Its up to you if you want to pony up for the better materials. Either one will work...
u can always just upgrade the ball joint later to the pro . its a better design and the bolts ar on the underside and will not jack up ur shock towers .
Fuster_Cluck
20
Aug 4, 2003 08:08 AM
