Barametric Pressure Need help !!!!!
Old Mar 26, 2009 | 04:32 AM
sirmugenpower's Avatar
Default Barametric Pressure Need help !!!!!
my ecu is throwing two codes it just started doing this ever since i put the motor in this car it didn't do it when it was in my other car but it now has a code 7 which is tps sensor and 13 which is barametric pressure but i never heard of it and if anyone knows how to clear this code please let me know because the car sometimes just shuts off on the highway while driving normal..
Old Mar 26, 2009 | 05:19 AM
seanbev24's Avatar
Default Re: Barametric Pressure Need help !!!!!
This link talks about the baro sensor and what it's for... http://www.hondatech.com.au/forum/showthread.php?t=102 , but honestly, I'm not sure where it is or how to test it. To lazy to dig out the manual.
Old Mar 26, 2009 | 05:32 AM
thanks bro but how can i fix this problem do i just replace the ecu or what should i do ???
Old Mar 26, 2009 | 05:52 AM
seanbev24's Avatar
No experience with the baro pressure problem, but most likely your ecu is fine. There's a separate code, 1 i think, if the ecu is bad. If you have access to a free ecu to try, than sure give it a go, but chances are you just have a tps and barometric pressure problem, whatever baro is.
Old Mar 26, 2009 | 05:59 AM
damn this sux cause im selling the car tomorrow and i don't want any cel coded to be on but hoplefully someone can tell me how to fix it or if it's even fixable thanks bro
Old Mar 26, 2009 | 06:11 AM
bump
Old Mar 26, 2009 | 07:42 AM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
Try resetting the ecu, disconnect the ground and power and leave it for 10 minutes or more.
Old Mar 26, 2009 | 08:09 AM
already did and it didn't work
Old Mar 26, 2009 | 08:35 AM
bump
Old Mar 26, 2009 | 12:26 PM
bump anyone know how to resolve this issue
Old Mar 26, 2009 | 12:31 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
barometric pressure is a MAP sensor issue. Hondas don't have a seperate baro sensor. It might be that the MAP is reading too high or low or something.
Did you switch the TPS and MAP sensor plugs while doing the swap? They're right next to each other and are the same shape. Check wire colors to make sure they're going to the right places.
Old Mar 27, 2009 | 04:28 AM
i didn't change the plugs cause it's a DA and the map sensor is on the firewall and not on the trottle body..but ill change the map today to see what it does
Old Mar 27, 2009 | 07:42 AM
bump
Old Mar 27, 2009 | 08:50 AM
standbackimapro's Avatar
Well your gonna wanna test the MAP sensor to see if its bad
youll need a multi meter, When there Is low Pressure in the manifold 5(Hg) there would be 2.4-2.5 volts at the sensor, the higher the Pressure in the manifold the lower the volts get .05 -.06 volts being the lowest at around WOT
Old Oct 27, 2009 | 05:16 AM
thanks i fixed it close thread
Ek4 life
Oct 4, 2012 09:30 AM
Hgoku10
Aug 4, 2009 09:05 AM
ekx4
Aug 31, 2005 11:49 PM
crxsiperf
Feb 26, 2004 08:29 PM
smkngsr
Nov 15, 2001 08:13 PM
