Built b16 turbo help!
hey, i have a built b16 turbo. ive had several issues with my setup. It has been professionally tuned(not by me).
issue 1- i am going through spark plugs reaaaally fast. I currently have an msd SCI box w/ blaster coil, cap, wires. I was told that my ignition was so hot that im actually burning the gap open in my spark plugs. I installed a new set of plugs 1 week ago at a gap of .022. after 1 week my gap was at .024. the last set of plugs i went through burned from .022 to .028 in 1 month. Im also showing signs of detonation on all pistons. piston 4 is the worst. i was told that the SCI box was most likely the cause of the issues.
issue 2- detonation. would the SCI box be causing my detonation?
thank you
thank you
b16a2 @ 81.5mm
darton sleeves
eagle rods
cp pistons
titanium valve springs and retainers
cam gears
brian crower stg 2 turbo cams
cosmetic head gasket
TB and IM
t3/t4 50trim @ 22psi
i do have a wideband in my car. under boost im high 10's low 11's
also have oil psg, egt, boost, water temp gauges.
it is tuned on ectune
darton sleeves
eagle rods
cp pistons
cam gears
TB and IM
b16a2 @ 81.5mm
darton sleeves
eagle rods
cp pistons
cam gears
TB and IM
darton sleeves
eagle rods
cp pistons
cam gears
TB and IM
What model plugs are you running ?
i started out with a gap at .028 and within 1 month i started having misfire issues at high boost becuase the spark was blowing out.
when i pulled the plugs the gap was at .032
1baddcivicsi
Oct 6, 2006 07:35 PM
