Help me with problem on mini swap
Okay heres the deal, everything on the mini swap is done, ecu wired, head and intake on, all wires re wired and conncected, but we have hoses in the wrong spot, im burning coolant and pooring out white smoke, and it has a differentiating idle from like 1k to 2k rpms. can any one help me out, maybe send me a picture of how your d16y8 intake manny hose connections are or maybe some 1 has a diagram. thanks in advance. Chris and Lawrence
you didnt clean off the block and head good enough before you put your new head gasket on. i jut went through this on mine. is your coolant resivour bubbling? white smoke means your burning coolant. sorry man
okay i fixed the idle, i forgot to plug up the ps vacum line cause i dont have ps. then i had bought another intake manifold with all the sensors on it but it didnt match the head. so i just swapped all the sensors to the intake manifold that came with the head and no more smoke...untilll i give it a little gas. now i am getting bubbles from my resivior, so what would you recomend me do to clean the head and block before i put on my head gasket
EGhatched
21
Mar 2, 2004 07:15 PM
